Question about Dell Studio 1737 Laptop
My Hinge plate buttons quit working all the time. I have had it replaced 4 times now, and It is getting a bit ridiculous. When its replaced, it will work for a while, then quit working all together. The Lights dont light up on start up either like they are supposed to. Dell Seems clueless, they just keep replacing it put soon my warranty will run out.
Freezer door won't close tightly and frost builds up
This is quite often caused by several factors ...
1] Worn door seals [REPLACE them] ...
2] Rusted door PINS [in older units] and/or worn PLASTIC BUSHES that support these pins [REPAIR or REPLACE them] ...
3] MISALIGNED and/or WARPED door [mostly in older units and/or if the kids hang off the door (especially young children) over an extended time ...
MOST doors are easily removed [but some are quite heavy and/or have electrical wiring/water lines etc. inside] so be careful. Usually you will need to remove the TOP hinge [screws usually under cover-plate] and then gently raise and lift-off the door from its bottom hinge pin. If you lift up the rubber door seal edge you will usually find a series of screws underneath. Just undo these to remove the inner shelf/door lining to replace the door seals. You can buy ready-made replacement seals from most major manufacturers and DIY ... or you can get a tradesman to do this for you [companies such as "SEAL A FRIDGE" can be found in your local phone directory or on-line] ...
Sep 21, 2014 | Refrigerators
As usual with the korg d3200 the locate buttons have gone in and will not work, the store button is the same and as a result i can't use the editing side. this is the 4th one that has suffored this problem...
If the buttons are just sticking at their sides in the panel, lube with a tiny bit of CRC 226 on a Q tip. Get the CRC226 at Home Depot in the electrical dept. If the button mechanisms have failed or plastic hinges have broken then replacement is only option. Losing 4 of these to same problem is RIDICULOUS... time to change brands.
May 01, 2011 | Korg D3200 Studio Package
WHERE CAN I GET THE WIRING DIAGRAM FOR MY TAYAMA RICE COOKER TRC-10? IT LIGHTS UP WHEN PLUGGED,BUT IT DOESN'T COOK WHEN PRESSED DOEN
Hi and welcome to FixYa, I am Kelly.
I do not have the wiring diagram but... the 2 wires that go to the top of the unit fray and break at the lid hinge point and cause this problem quite often. The 2 wires in the hinge area are for the upper temp sensor. (The floating plate in the top of the lid) If you fix the wires in the hinge area most of the time the come back to life unless the heating element has failed. The heating element will read about 180 Ohms resistance if it is good. The resistance changes a bit as the unit ages.
Try fixing the wires in the hinge then testing the cook button. I usually have extend the wires in the hinge and do a double splice for the NEW wire strip on each wire with heat shrink tubing over the repair.
If this does not work just respond here and I will assist you further.
Thanks for choosing FixYa,
Kelly
Jan 28, 2011 | Tayama TRC-10 Rice Cooker
Freezer door opens very slightly when refrigerator door is shut. How do we get it to keep from popping open?
there are only two things I know of that will keep the freezer door from closing . First , visually inspect the freezer door seal that goes around the outer edge of the inside of your door . If it is out of shape , torn, etc. , replace the seal . If OK , then your door hinges are probably worn down . Sometimes , you can adjust the hinge plate which will align the door enough to close properly . Remove the top hinge cover plate with a screwdriver or nut driver to access the three adjusting screws holding the hinge plate in place . Be careful to not misalign the door worse then it is already . It may take a few times with trial and error but it can be done . Of course replacing both hinges is the best option . a specially the bottom one as it is the load carrying hinge .
Nov 18, 2010 | Jenn-Air JCD2290HES Side by Side...
Replace my drivers side door hinges on 1997 dodge full size van
Access to the bolt heads is through holes which are generally exposed once any interior trim has been removed. The lower hinge bolts are relatively easy but the upper ones can sometimes challenge the most supple of people. Sometimes other dashboard or instrument stuff must be removed or pushed aside. Sometimes such things as the fusebox must be removed.
Vehicle specific information could make your job easier.
If you have never replaced hinges before or removed a door, you have yet to experience the frustrations of door adjustment and the joy of finally getting it right with equal panel gaps all the way around and closing level with the surrounding panels and without riding up or down as it contacts the striker plate.
The latter point is of great importance if premature wear of the catch and the striker is to be avoided.
It is a job that should be faced without time constraints; quite simply it takes as long as it takes and for a novice that can be a long time.
If the hinge pins can be removed easily and refitted in situ and it is only the door side of the hinge that is worn then fitting half an hinge might make the task easier. It depends on the design.
Sep 07, 2009 | 1997 Dodge Ram 2500 Club Cab
Can't remove cover to check power supply.
Remove the bottom base according to user manual, clips into the bottom, pinch them together with your finger under the base. Then remove hinge cover in back of panel by popping off the plastic cover with a flathead screwdriver. Then remove the 4 screws holding the metal plate. Under the plate are two screws. remove them and then carefully pop the case open. The 2 screws are the only hard fixed part holding the case together, plastic snaps hold the rest. Also remove the 4 screws in the back of the unit. Remember where everything goes, write itdown, there are several plugin modules you will need to remove when disasembling.
Mar 31, 2009 | Westinghouse SK-19H210S Television
Frigidaire fridge door makes a loud popping sound
You need to take the door off the hinges and remove the lower hinge plate from the bottom of the door. This is where I found my popping problem. The black bushing with the 3 bumps and dips on it is loose in the plate going into the door. I took black eletrical tape and rapped it around the part that goes into the plate to tighten the bushing up so it wouldn't turn anymore. ( This was a temp fix to see if the popping would go away) 3 Weeks later and still working. If the sound comes back I will put some double sided sticky back foam on it. Both doors were doing this on my fridge, and now its as quite as a mouse. I hope this fix works for you.
Dec 29, 2008 | Electrolux Frigidaire Professional Series...
Casio HD wristwatch-4-button
1. Press lower-left button to enter hand-setting mode (you will see a H-S appear in the LCD)
2. Hold the upper-left button until the LCD starts to flash
3. Press the lower-right button to advance the minute needle by 20 seconds. You can also hold for high speed advance.
4. If you need to advance the time by a long way, and don't want to hold down the lower-right button, then press both the right buttons at the same time and the time will advance automatically. Pressing any button will then cause the advance to stop.
6. Once you have set the time, press the upper-left button.
7. To return to time-keeping mode, press the lower-left button.
Bloody complicated, but easy when you get use to it. I travel quite a bit and this really pisses me off when I have to change the time, especially so when the needle can only move clockwise.
-Bala
Nov 06, 2007 | Casio WVA430A-1AV Wrist Watch
Door catch plate Indesit d61
undo the screws at the top of the front door and puul the control unit out this gives you acsess to the door catch which is quite simple to replace be careful the stainless steel is quite sharpe
Dec 03, 2006 | Indesit 24 in. D61 Free-standing...
Dell Studio 1737 Laptop Logo
97 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
