Question about Samsung HLR5067WX 50" Rear Projection HDTV
When we turn on the TV, the little green "lamp" sign comes on; after a bit the "Timer" light comes on; then later the "Stand By/ Temp" light comes on. Finally they all turn off and the TV never comes on. We have had the lamp replaced once. TV is about 3 yrs old.
  • Samsung Master
  • 8,457 Answers
The lamp u change?U use the tv at lest 4 or 5 hours a day?The lamp 1 1/2 or 2 years last was change?The lamp life span is over replaced other lamp.
Posted on May 11, 2010
  • Chi Chu May 11, 2010
    U hear any clicking when ur lamp light LED indicator flashing?Than ur ballast is dead.
Samsung DLP 72" HL72A650C1F keeps turning off amd on
Did you buy the original lamp?
If the problem is related to the lamp door switch, you will get a different error instead of lamp LED.
Do you hear the color wheel spinning?
Again, if it's a color wheel problem the error will be different!
My good guess is the lamp but, it could be the ballast or both.
Best of luck
www.aaatvservice.com
May 08, 2012 | Samsung SELECT HL72A650C1F Rear Projection...
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Put a new bulb in that i got from e-bay, tv switches on perfect but after a little while it turns itself off then red and green light start to flashing. i don't know what the problem is ????
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions (for samsung) :
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks
Mar 14, 2011 | Televison & Video
I have a zenith e44w46lcd tv, while watching it, it turned off and now will not turn back on again. Green light flashes for a bit then goes back to red. Also lamp light is on orange. Do I need to replace...
More then likely your lamp is faulty, you can replace this lamp urself, but on zenith models the lamp comes as a bulb only, you will have to change the lamp and use your original housing. Also lamp timer will have to be reset. The only reason you might need a repair man is to go into factory mode and reset lamp timer. But if you are mechnically incline you can swap the lamps yourself..
Thanks any questions email me at -
Delhielectronics@live.com
Sep 27, 2009 | Zenith E44W46LCD 44" Rear Projection...
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Tv turns on for about 1 minute then turns off by itself
could be the lamp. It is consumer replacable.
Aug 10, 2009 | Televison & Video
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
147 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
