Question about Western Digital External USB 2.0 80 GB Hard Drive
My Book external hard drive
My external hard drive's (MY BOOK) fan is running, it is plugged in (and has been checked), it is connected to my USB port (and has been checked) but it is still not booting up on my computer. The computer does not recognize it as a drive and it does not sound like the drive is running other than the fan noise. It used to run a lot and now I cannot hear it at all.
Penny
I had the same problem it was the eartconnection inside the hardrive just dissmantel the hardrivebox and clean the earthspaces. this is because the usb cabel dont provide enogh power
Posted on Apr 10, 2008
    Sergeant:
    Champion:
  • 329 Answers
Have you check the bios of your computer? check if first! it seems that some utilities have been disable... check it! i hope i help you! thanks!
Posted on Apr 03, 2008
My book doesn't have power
Did you plug it in?
USB Powered Devices:
If you're using USB for power then you either need a powered USB hub or the device must connect directly to the computer's USB port bypassing the hub.
If the USB hub doesn't plug in to the wall socket then it is not a powered hub. Basic USB hubs do not supply power to devices or charge an external device like a cell phone. The hub must be of the powered variety and plug into the wall before you can use it for things like this.
TIP:
Get two USB hubs, one powered and one not. If you're using a USB hub for anything other than connecting a flash drive or your wireless keyboard and mouse receiver, get a powered one. Doing so allows you to charge multiple devices through USB and it will provide power to other peripherals like a laptop cooling pad, external hard drives, etc.
Sep 29, 2012 | Western Digital My Book Essential 1TB...
I have a WD My Book 1 TB external drive and it worked until just now. When I connect the drive to the wall I hear it spinning for about 5 seconds and then it stops. The blue lights are not coming on. Could...
Make sure you have the usb connected directly to a port on the pc. Also check the power supply with a test/voltage meter that is working and outputting the correct voltage.
Thanks for using FixYa
Oct 31, 2011 | Western Digital My Book Essential 1TB...
Computer won't recognize external hard drive anymore
Have you tried changing the USB cable or connecting it to a different USB port on the computer?
Nov 14, 2017 | Western Digital 320GB MyBook External USB...
Computer doesn't recognize hard drive
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Feb 14, 2010 | Western Digital My Book Essential 1TB...
My external hard drive wont conect to my computer.
Is this a new drive? has it worked before? the usual sequence is to connect the external drive to a power source first, and then connect the usb cables to the PC. IF you know the usb cables are good and have verified that they are connected properly, try connect to a different usb port on the PC, sometimes ports go bad. If that still doesn't work, the most likely the hard drive has gone bad.
Oct 03, 2009 | Computers & Internet
Windows Server trying to boot from external hard drive
go into your 'update settings'. there is a section of where it asks you about how you want your settings set and where to send updates to. You may find the problem here. Check all the 'advanced' settings as well. If your Western digital is plugged in via USB and not requiring updates, unplug it while starting your system, after complete start up, reinsert the USB plug. It may show new devise found, then from here, you may be asked to reinstall it to stop the rebooting.
Aug 24, 2009 | Western Digital My Book Essential Edition...
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
Hi, I recently bought your 750GB My Book external drive, which I have connected to a Macintosh G4 desktop computer.  The computer does not recognize the external drive now, although I was previously able...
Be sure to plug the USB connector and the back of the CPU. Then go to Application folder if your running on OS X. Locate the disk utility, then double click it and see if your external drive have been detected. If it is detected try to repair it. and then thats it
Dec 07, 2008 | Western Digital My Book Premium ES...
I recently purchased an external hard drive, and how do connect it to my computer.
External Hard Drive is mostly of the USB interfacing type. If urs one is the same, then it is just as simple as plugging in a pen drive in the USB port. If it has external power supplies then u can easily figure out how to connect. There are two parts in the power supply (if external power supply cable is provided), 3-pin main power supply connector and other is the adapter which goes to the external hard drive.plug in the other end of the adapter into the hard drive (there is a hole in it). connect the main power cable to the adapter extension. now for the usb Hard Drive, connect the USB cable to the USB port of the computer. Switch on the power supply to the Hard drive and u r ready to use ur brand new External Hard Drive. If it is a Firewire interfacing one then u may need to open the CPU box, and then connect the firewire connector on to the motherboard firewire port. It is easy to identify, it is a red colored port/connector.
Oct 11, 2008 | Western Digital 500GB My Book World...
I have a "My Book", Essential Edition, External drive, which a friend set up for me with a lot of information on it. When I plug in the USB and the addaptor (after having my MAC Book booted up),...
gud day...does ur mac book support any plug and play device? if it is then try to plug it to ur another usb port if it doesnt work...there sumthing wrong with your mac book.,it means that your mac book doesnt recognize the hardware to attach on to it...or ur mac software doesnt support the external hard drive...mac book operating system doesnt work with your essential edition external drive
Jan 14, 2008 | Computers & Internet
Western Digital External USB 2.0 80 GB Hard Drive Logo
82 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
