Problem with HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook
Compaq C751NR need windows xp - conexant HD audio smart audio 221 driver
I recently purchased a Compaq C751NR. It came loaded with Vista. I want to install XP pro on it. I am having problems finding driver . The device is Conexant HD audio smart audio 221. Any help would be greatly appreciated!
Posted by avatar on Mar 28, 2008
    • By avatarlonglanky Mar 28, 2008
    • I have already tried this driver. It does not work with XP. Thanks
    • By avatarlonglanky Mar 29, 2008
    • Big improvement in performance with XP!! Thanks
    • By avatarlonglanky May 27, 2008
    • See if this will helphttp://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=ob-45570-1&cc=us&lc=en&dlc=en&dlc=en&lang=en
    • By avatarsoar3_sorin Oct 18, 2009
    • Heloo! i have a Packard Bell ME35 Echo C ...and i installed xp ...i found sound driver with Solution #3...thankt's It works....i have SOUND ON MY LAPTOP :D
    • By avatarGuest May 14, 2009
    • this post rocks!!!
    • By avatartriphop Apr 17, 2009
    • I need your help i have compaq presario c700 i need the audio driver im using win xp now
    • By avatarneleplnovako Apr 09, 2009
    • Sorry some mistakes in typing. Compaq presario C758ca and i can't make it work
    • I tried all this and my sound still doesn't work
      I have compaq presario c75m ca laptop, i downgraded to windows xp
    • By avatarGuest Mar 04, 2009
    • Compaq V3700 need windows xp - conexant HD audio smart audio 221 driver" problem
    • By avatarsoju Feb 21, 2009
    • i am alsso facing the same problem wih presario v3000
    • By avatarniaz_mb Feb 11, 2009
    • smart audio 221 driver needed
    • By avatarGuest Feb 09, 2009
    • i have problem with audio
    • By avatarmohsin_h Jan 21, 2009
    • i have Compaq PresarioC770TU with Conexant HD-Audio Smart audio221. M using windows XP, my sound card is working fine but i cannot use the Microphone, external MIC is also not working.
    • By avatarpradeepabp Dec 18, 2008
    • System unable to reinstall conextant HD smart audio 221
    • By avatarLorijong Dec 02, 2008
    • Compaq C751NR need windows xp - conexant HD audio smart audio 221 driver problem
    • By avatarGuest Nov 22, 2008
    • need windneed windows xp - conexant HD audio smart audio
      m,,ows xp - conexant HD audio smart audio
    • By avatarGuest Nov 19, 2008
    • Yes, I have the same problem. Plus the video is not working
    • By avatarGuest Nov 15, 2008
    • after formatting the laptop the sound driver did not found in property of my computer
    • By avatarmohsin_hiran Nov 13, 2008
    • sound card drivers (Conexant HD smart audio 221) for Compaq presario C770TU
    • By avatarGuest Oct 27, 2008
    • I CAN'T ABLE TO INSTTAL IT
    • By avatarmhin Oct 13, 2008
    • i downgraded my c751 pc notebook from windows vista to windows xp with that i lost the audio of my laptop what will i do? can you help me?
    • By avatarmajid472 Sep 15, 2008
    • c751nr audio? any suggestuin?
    • By avatarssmogunov Sep 06, 2008
    • I need Audio driver for Windows Xp for Compaq Presario C751NR
    • By avatarGuest Aug 02, 2008
    • pas de son
    • By avatarTNguyen Jul 25, 2008
    • I have just bought a Compaq Presario C751NR and I would like to downgrade from Windows vista to Windows XP. Howerver, I can't install audio driver. I follow the instruction to install from a specific location C:\swsetup\SP34200 and the C:\swsetup\SP34204. My .inf file is at8ven5a (don't have w30b2a). It tried to install the driver, but No Audio device is the result! And on the Device Manager, there is a yellow exclamation mark for a Conexant High Definition Audio.
      Please help me :).
    • By avatarVladiown_wd Jun 27, 2008
    • I was not able successfully to find the Conexant High Definition SmartAudio 221 driver for Windows XP to my Compaq Presario V6719NR notebook. I've tried to install many different drivers, but I'm still not lucky.
      Please help me to resolve my problem. I'm really appreciate your time very much.
      Thank you,
      Vladi
    • By avatarGuest Jun 15, 2008
    • i need the driver for windows xp pro cause the sund target conexant HD-Audio SmartAudio 221
    • By avatarGuest Jun 13, 2008
    • modem device on high definition audio bus for compaq presario C751NR Notebook PC
    • By avatarMrKleks Jun 04, 2008
    • I have it too :(
    • By avatarSHAFEEQ23 May 19, 2008
    • conexant HD audio smart audio 221 driver problem
    • By avatarGuest May 18, 2008
    • sound not working in compaq presario c754 notebook for XP operating system. pls assist me.
    • By avatarkuttabilli May 08, 2008
    • compaq c751nr needs windows xp conexant HD audio smart audio 221 driver problem
    • By avatarGuest Apr 22, 2008
    • I've tried installing some Connexant HD audio drivers i downloaded but none of them has worked. I tried the Compaq website and was instead redirected to the HP website. I was told that a device driver for this Hardware is not currently available for Windows XP Operating systems. Awah Emmanuel, emmasom1@yahoo.com
Solutions (25)
Best Solution
    • By avatarDave MacPhee Mar 29, 2008
    • Found this if it helps:
      ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
      This will create a swsetup folder in c drive ("C:\swsetup\sp34200")
      Installing this driver may result in an error. But continue with the
      following steps to get the audio driver installed correctly.
      1. Click on Start and select Run. Now type devmgmt.msc and press enter.
      2. Right click on "Audio device on High Definition Audio Bus" and click
      Update driver.
      3. Select "Install from a list or specific location"
      4. Click Next. Then select "Don't search, I will choose the driver to
      install"
      5. Click Next and then select "Sound, video and game controller" from the
      list.
      6. Click Next and then click Have Disk.
      7. Click Browse C:\swsetup\sp34200 folder and select the .inf (wis30b2a)
      file and click open and Continue with the onscreen instructions.
      Hope that helps!
    • Glad I could help!!! And thanks for changing my rating, that was very kind of you!
  1. View More Comments
I downgrated from Window Vista to Xp, installed all driver, the sound card still works but I only hear the sound, canno't use Microphone, The external Mirophone doesn't work either
try this driver , it works for me
...install by clicking on setup.exe
http://rapidshare.com/files/334110156/cx20561_hd_smart_audio221xp.rar.html
if you check the compaq/hp website you need two sets of drivers for hd audio chips.
one being realtek
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
the other being the microsoft uaa universal audio, one does not work without the other.
stop looking for a single conextant driver,
check here to confirm
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01500841&lc=en&dlc=en&cc=us&softwareitem=ob-56632-1&product=3817873&os=228&rule=4595&lang=en
i spent days finding this out,
hope it helps you all
Dazza
i have a problem with my soun card; conexant high definition smartaudio 221, i
I recently purchased a packard bell ME 35 laptop. It came loaded with Vista. I want to install XP pro on it. I am having problems finding driver for the sound card. The device is Conexant high definition smartaudio 221. Any help would be greatly appreciated! Thanks
the links not found.....
  • By Author imageGuest Aug 13, 2008
my smart audio is corrupted in control panel help me to restore it again
  • By Author imagehuzzic Aug 04, 2008
The low sound microphone problem can be solved using the Smart Audio control panel. There are 3 different microphone options which can be set.
  • By Author imageGuest Aug 03, 2008
great...post..it worked flwlessly//
  • By Author imageGuest Jul 20, 2008
After 3 days of trying this that and the other. THIS is THE only thing that helped me on my downgrade from Vista to Xp on a HP G6000xx laptop! Audio is now fully installed.
Many thanks
great it's work~but mic no fuction~it's that my hardware problem or driver problem?
  • By Author imageGuest Jun 27, 2008
everything works great!!! on my hp pavilion dv2715nr works the instruction with sp33543driver conexant high definition smart audio 221 Thanks
  • By Author imageGuest May 02, 2008
I guess this method would be seriously awesome if HP/Compaq would stop being jaggs about this and allow it even be downloaded anymore.
Seemingly they've disabled the download and only have the links for show.
MSFT must be complaining how nobody wants to keep Vista on their machines....
  • By Author imageGuest Apr 19, 2008
I've upgraded the driver from HP sp34200 version 3.26.0.0 to 3.45.0.50
using the files from Microsoft update catalog. This driver is now
3.45.0.50 and includes STEREO MIX. You can use the setup.exe for
automatic install.
Note that due to changes, the driver is obviously no longer digitally
signed.
The driver matches: HDAUDIO\FUNC_01&VEN_14F1&DEV_5045&SUBSYS_103C30D9
The driver is for XP 32-bit, for the compaq presario C700 series.
http://www.mediafire.com/?d74hkani6q69rr3
  • By Author imagenico Nov 05, 2011
Hi, I had the same problem and, after 12 hours of working on it over the duration of a summer, I finally found the driver you are looking for.
http://dc97.4shared.com/download/56393097/ac5d28f0/ConexantHDAudio_221_XP.zip?tsid=20
First, uninstall and drivers you have installed for the device. Run setup in the unpacked zip file (and it may give an error about a MEDIA device missing), then restart your computer. When you get the windows xp "add new hardware wizard", choose the "WiSVHe5" file as the driver in advanced mode. Then, in device manager, go to properties->properties->right click on audio device, and then properties one more time. Make sure it is NOT mapping through the device, and that it is using it.
Hope this helps, Paul.
Visit HDA_HP221
  • By Author imagehuh3 Sep 18, 2009
right Click on the sound icon on the task open file and go to properties put a check mark in the box for mic and then it should work
I have a Compaq Presario Notebook PC and the device is Conexant HD audio smart audio 221. There is a note that tell me that "this device has installed successfully but still doesn't work correct". So what can I do? I have removed Windows Vista and I replace them with genuine Windows XP because the Intel Celeron was too weak to handle the Vista operation system. Have you any idea to tell me what to do? I will expect for your advice. Thanks anyway, Erik.
omfg you saved the day, thank you sir :)
  • By Author imageGuest Nov 03, 2008
hepl
  • By Author imageGuest Aug 25, 2008
i was able to make the sound work. but i can't make the mic work. what should i do? where can i get a download?
  • By Author imagemdv724 Aug 11, 2008
good one..really helps
  • By Author imageGuest Jun 22, 2008
Suggested Solution (2)
most of the disk drives on anytype of lap top would always be on the side if not then you just don't have one
  • by Author image Pocahonas Over a year ago
Source: Compaq C751NR need windows xp - conexant HD audio smart audio 221 driver
Was this solution helpful?
No
Yes
Add Your Solution
See all HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Problems
