Question about GE JBP30 Electric Kitchen Range
Range Oven clean cycle problem
My J BP30B A4AD GE Range won't complete the self clean function. On most tries, after what appears to be a good start, the oven and clean lights begin blinking; the oven fails to heat. Once the oven began to heat nicely but then stopped showing an F2 error code. I have checked the oven door lock and am certain that I am moving the lever all the way to the right. Pursuant to the manual I have let the oven cool and unplugged the electricity before beginning again. No luck. What's next?
  • GE Master
  • 3,740 Answers
An F2 error is the oven temp exceeded 590 Deg with the door unlocked.
I know you have been troubleshooting the door lock issue. There can be a problem with the micro-switch actuating arm of the door latch assembly.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-+JBP30BA4AD+-%3d%3dei245065&PartID=245065
If the actuation arm is bent you will get the symptom your describing. You can attempt to bend the actuating arm "upward" on the microswitch. The curved end of the arm should be even with the curved latch swing arm hole end when properly adjusted.
The switch can also be failing electrically with heat but highly unlikely. You may end up changing out the door latch assy. listed above to correct the problem. I still believe you can just adjust the micro-switch and save yourself some money.
Thanks for using FixYa.
Kelly
Posted on May 11, 2010
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
How do you unlock the control locked function on a Maytag Gemini elec. range?
If its a self cleaning unit, try start the self cleaning cycle, then cancel it. If that doesn't work let the self clean cycle finish completely and it should go back to normal.
Mar 15, 2015 | Maytag Kitchen Ranges
When trying to use either upper or lower oven, panel flashing "Control Locked." Won't work.
Try this:
ToChangeFactorySetDefaultOptions:
1, Controloptionsmay be changedby se-
LectingtheSetupOptions(0)padandthe
desiredoptionpad.(SeeOptionsbelow.)
2. Currentoptionwillappearin thedisplay.
3. PresstheAUTOSETpadtochangethe
option.
4. PressCANCELpadtosetthe displayed
optionandexittheprogram
The LOCK is option 4 change the OPTION from 4 to 9.
9 is the factory default settings.
This should work. However.... there is the possibility that the unit had performed a self clean function. If you just completed a self clean cycle it can but up to 1 hour AFTER the cycle before you can open the door or use the oven as the range must cool down and cycle a thermostat before it wil work again.
There is also the possibility that the door lock has not completely retracted. If you can get it to start a self clean cycle.... after 1 minute press cancel and the lock should retract. (I know you said won't do anything) I am hoping that after you reset the options from 4 to 9 that you might be able to do this.
Thanks for choosing FixYa,
Kelly
Sep 06, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Self Cleaning Oven
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 31, 2010 | GE Profile 30" Self-Cleaning Drop-In...
After self cleaning cycle was completed and the oven cooled to room temperature, the oven will not come on. When set to an oven temperature, only the self clean light flashes - no oven.
you may have blowen the hi limit to oven . not uncommon after self clean cycle .. if digital oven / shup power off for 5 min then reset. and try again ..
Dec 02, 2009 | GE JBP60 Electric Kitchen Range
Locked door on my GE Profile Oven (Range)
Amazing. I've searched across the web, and this "locked door" problem appears to be a DESIGN FLAW across the entire product line: if you run the self-cleaning cycle, it WILL trigger this problem and despite the suggestion of a wide range of "self-help" strategies, the only real solution is to pay for a service call (and then, it appears, paying for a new control unit and probably an additional service call to have it installed, and then more service calls if the same problem occurs). We have a JGB900BEF2BB GE Profile range, and of course we've run through all the self-help suggestions at geappliances.com and on a dozen other web sites like this one.
Oct 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Whirlpool RF367LXS Ceramic Glass Range not working
Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
Feb 02, 2008 | Ovens
GE JBP30 Electric Kitchen Range Logo
143 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
