Problemw with digital TV signal using an arieal
I live in a dip that is about 10M below the surrounding area. I have a digital ariel, proffessionally installed and a signal booster. In bad weather the receptoin becomes fragmented. What can I do?
I recently purchased an ilo 32 inch tv and am having problems because when I first purchased it I had it connected to a cable box now I no longer have the cable box just the cable and am unable to hook it up because the connecter does not hook up to a regular cable cord is there a special connection that hooks it up directly to the cable cord? I read in the manual something about a F-type connector where can I get one?
Posted on Mar 28, 2008
Tv has no signal
The TV you are trying to connect to may be an older type and not a DIGITAL receiver. The old ANALOG type no longer work with the Digital applications unless to have a CONVERTER BOX.
Dec 22, 2013 | Televison & Video
Have tried with different ariels and still cannot get any digital channels on tv can get analogue with a struggle tv keeps telling me no signal
First check there are digital channels come in your area?If yes then select digital channel to auto tune. If still have problem then need to replaced tuner.
Nov 04, 2010 | Televison & Video
Itv and ch4 channels have no signal on my digital
First check with some of your neighbours to find out if they have the same problem if you are using a communial aerial, if thiers are ok, try re-tuning the TV from "Auto tune" in the set-up menu, this will retune the entire TV & should pick up the missing channels.
Apr 14, 2010 | Televison & Video
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Tried to rescan after digital change over and it wont keep the signal, i have digital tv and digital ariel
Sounds like you have weak signal in your area, unlike analog TV , if the signal strength is below a certain level it will completely reject channals, try a standard antenna with two rabbit ears and a loop. If your TV has a signal strength meter you can watch that while adjusting the antenna.
Dec 15, 2009 | Televison & Video
Alighn ariel for digital tv
The best type of aerial for digital reception is to use a wideband aerial this will give you a better spectrum to receive the signal. To locate the aerial position, if you know in which direction your local transmitter is situated, then point the aerial in that direction. The best way to find out which way to point is to simply look around at any of your neighbours aerials & then aligned yours in the same direction. If you are using a spectrum analyser as your sattelitte finder then you can use this to find other frequencies in the signal range.
Sep 06, 2009 | Televison & Video
Tv ariel
Okay most likely your are is in digital conversion area witch your going to need a digital box.. you can get on the goverment rebate/coupon program to take the cost down.
Apr 21, 2009 | Televison & Video
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
No signal on my goodmans xpro freeview on the flat screen it says
hi there the first thing i would make sure you have a wide band ariel capable of receiving free view if the ariel is old and was there before you moved in and you have been there a while theres a good chance that the ariel isn't a wide-band ariel,
also check here with your post code to make sure free view is transmitted in your area
http://www.freeview.co.uk/availability
if you know you can get it and you have a wide band ariel make sure all connections are secure and that you don't have many leads connected together because you will lose a vast amount of quality though many leads to a point where you wont get a picture also make sure its the only tv on the connection as having a few will also do the same thing. ariel boosters can make a massive improvement on the line these can be bought any where even you local asda/walmart, make sure you have one secure connection right to the ariel socket to your tv. this eliminates any other problems
make sure you have your tv tuned in right if you have just moved house you will need to rescan for Chanel's as they can be on different frequencies from where you last lived
I hope this helps you if you Need a maual for your set please leave make and model number from the back of the set and ill try and get u a online manual for this set
Good Luck Hope You Sort It
Feb 03, 2009 | Archos AV 500 400-Hours Video Recorder
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
