Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
When I try to write the response is : unit protected, impossible to write. When I read something all is OK Do you have any suggestion for me?
    Genius:
  • 1,354 Answers
Have you given any pass on your HDD if no then just folow the steps
go to my computer then properties
y wiil have opetion on that page
alow me to red and write
m42153
Posted on May 12, 2010
My minidisc recorder is showing 'protected' message when I try to record. Minidisc is blank and new. Problem is not with the write protection tab.Any suggestions please?
There are only two possibilities - there IS something wrong with your write-protect tab (try opening and closing it once), or there is something wrong with the little arm that reads the tab (perhaps it got bent).
What happens if you use a different disc?
Aug 08, 2013 | Audio Players & Recorders
WILL NOT TURN ON
Sorry to read about your problem, I hope this helps you out.
1. Do you have power to the unit, lites on, buzzers work etc.
2. if you have power, you may have a defect start button or timer
3. if start button/timer is ok you can have a defective motor.
I suggest you call service company, that have the proper equipment to work on your unit
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Whirlpool LER4634J Electric Dryer
My Whirlpool Duet GHW9200LQ front load washer will not turn on. The only light that is illuminated is the bottom cycle light (it says controlled or something, the letters have worn off). I tried...
you have a complete failure, i suggest you contact a service company, since your unit is dead, and you tried to reset the unit
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No heat all vents clear. Where would the fuses or breakers be located on this unit.
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective.
Their is no fuse to check, their are thermal protective devices on the unit.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
3 Thumbs - Helpful
Dec 26, 2010 | Kenmore Elite HE4 Electric Dryer
Hallo. I have a Prosonic TV type LC-27M65 that will not switch on. The red control light for remote is on. The yellow light indicator for current is off. Although TV is connected to net for power, the...
It is possible that your TV has encountered a fault in the power section possible a short in the drive power section. hence on powering the power sully working OK is switching the secondary power to the main board but this short is taking in more current than specified. the feedback of this is read by the SM unit to shut off the power to protect the supply. Hence you will have to probe into the sections to find this short, perhaps a HT drive transistor or the HT transformer or capacitors. If will be easier to check the continuity with a meter. Please attemptt only if familiar otherwise take help. Disconnection of the shorting section will switch the power, replace teh component in question. Hope you try. Good day
Aug 16, 2010 | Prosonic Televison & Video
How to protect cd/dvd copy and write
If you are trying to write a CD/DVD that can be read, but cannot be copied, you're asking the impossible.
May 13, 2010 | Computers & Internet
Dra-685 the protection came on ,i found 2 speaker wires together,fixed that,but still stays on,thanks
You may have a speaker that is damaged and causing the protection to operate. Try unhooking all the speaker wiring from the receiver, turn the volume to minimum, and see if the protection still comes on. If the receiver is okay, you can start checking the speakers and wires to determine which one(s) may be responsible.
If the unit continues to go into protection even with no speakers connected, the trouble is inside the receiver. No protection circuit is absolutely perfect, so it's possible something failed before the circuit kicked in. Without the proper test equipment and service information, you won't be able to try fixing this yourself. Take the unit to a shop for an estimate.
Thanks for using Fixya! Hope your receiver's back in service soon.
Feb 02, 2010 | Denon DRA-685 Receiver
My DVD recorder doesn;t record. When I go to replay there is nothing on the Recorded list. (The message PSO is showing on the front of the recorder.Is this coneected?)
Ok recording is impossible.
1.this unit may not record programs that contain copy protection signal.
2.Check that there is nothing on the disc to start off with.
3.check that the disc is CPRM compatible.copy onc programmes can only be copied onto the disc which is CPRM compatible.
4.check if the the disc is protected or finalised.Undo the protection or the finalisation.
5.DVD-RW usually once formatted in another unit cannot be recorded in your unit unless formatted.
6.Check all connections are properly made.
Oct 18, 2009 | Televison & Video
Samsung home theater
After having my unit for a year, it now reads this PROTECTION message. I tried to restore factory settings also before calling Samsung & they said something wrong with the cooling fan. Haven't tore into it yet, but does the units come with a fuse that might be blown. I'm tring to find free schematics on the net but hard to track down. If you just got yours, take it back to the store & get a new one!
Oct 06, 2007 | Audio Players & Recorders
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
75 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
