Question about Hori Protector for Nintendo DS Lite
Hi i just got a hori screen protector and have already applied it but there are some significant bubbles underneath the screen and with a closer look you can see that there dust inside the bubbles. Is the anyway to remove the dust from the sticky side of the protector?
    Novelist:
    Champion:
  • 207 Answers
You can wash it with warm soapy water. just rub it gently and rinse. once washed shake it to dry it off. don't let it sit and air dry for you could end up with more dust on them. if you can use a tweezer to hold one corner as you dry it and try not to get your fingerprints on it. these things are like glass magnet once clean and dust free they'll stick back on the screen. once you have it clean and dry try placing it on the screen best you can and squeeze out from the center and press out in all direction. if your placement is wrong replace it before starting to squeeze out
Posted on May 12, 2010
Why won't my LG Stylo 2 Plus screen protector seal??
Simple it was not applied correctly.Use a mild dish soap solution and squeeze the water out as you apply it.
Sep 20, 2016 | T-Mobile Cell Phones
How do I get all the bubbles out after applying my screen protector
Use a hard edge like your drivers license or credit card. Work them slowly to the edges.
Next time use an alcohol wiper on the screen just before you apply the protector. This will help with removal of the bubbles.
Jun 15, 2016 | Empire MPERO Collection Ultra Screen...
Remove air bubbles from cell phone screen saver
Peel off or otherwise remove the screen protector, spray the adhesive (sticky side) with glass cleaner, then reapply the protector and use a credit card to roll out the air bubbles.
Nov 20, 2014 | Ericsson SCREEN PROTECTOR MEXXPROTECT...
Touch screen has white bubbles
If this is a tablet, the bubbles may be forming under the screen protector plastic. This can be fixed by using a credit card or other plastic to gently push the bubbles out the sides.
If this is a different type of touch screen is may be separation of the protective layer from the touch screen / digitizer. The same solution may apply here assuming the adhesive between the protective layer and touch screen has not become "non-sticky"
Please provide more details if the above does not help.
Sep 06, 2014 | Acer AZ5610U9072 Allinone PC 23' Touch...
Smartphone how can i replace screen protector without air bubbles like Pro does ?
Before putting the new protector on the screen must be completely clear of any dust/dirt. I use an alcohol wipe first to clean the screen then a clean microfibre cloth to dry the screen and wipe away any remaining small dust particles, then slowly apply the new screen protector like in the video above
Apr 16, 2014 | Apple iPhone Smartphone
Iphone 4s shins
Step 1: Clean your workspace. Be sure to get a flat, hard surface without a lot of fabric, liquid, dust, etc.
Step 2: Lay the phone down and clean it well with the cleaning cloth provided. Do not use any kind of cleaning fluid or water, but try to be sure that all fingerprints are gone. Especially be sure no dust or lint particles are on the screen. Before proceeding be sure that there are not a lot of dust particles gathering near you, vaccum and clean the area up a bit more if need be. You want as sterile an area as possible before continuing.
Step 3: Being careful not to touch the sticky side of the screen protector, peel back the tab where indicated. Hold the screen protector only by the sides and line it up with the phone. If you touch the sticky side of the screen protector by accident do not try to clean it off, you will only make it worse. Line up and let the screen protector fall into place from the top of the phone to the bottom. Some people choose to use a credit card or thin piece of plastic to smooth out bubbles as the screen protector makes contact with their device, however this is usually not recommended by the makers of the screen protectors or the phone. The choice is yours, but bubbles are meant to smooth out over time, so take that into consideration.
Steap 4: Once the screen protector is on the device if it is straight and you can see bubbles but no lint or dust beneath it, you are successful, give it a few days for the bubbles to dissipate. If it is not on straight, you may be lucky enough to be able to lift it up and place it better without fault, however this is risky. If lint or dust has gotten between your phone and the screen protector you have likely failed, there is little recourse from here, other than removing the screen protector, cleaning the device, and trying with a new screen protector altogether.
May 24, 2013 | Cell Phones
How to change my iphone screen protectors?
Ease of Application and Removal. You shouldn't have to be an accomplished brain surgeon to apply a screen protector properly. The best protectors go on easily without leaving air bubbles or requiring constant repositioning. If you do need to adjust your protector, it should move easily so you don't have to throw it away if you don't get it right the first time. If you want to remove the protector altogether, it also shouldn't leave sticky adhesive residue on your screen.
Dec 28, 2012 | Cell Phones
How do you get bubbles out of iPad screen protector?
To lift the protector off one edge of the display, place a sticky tape on the edge of the protector and then pull on the sticky tape to lift off the protector.
Lift the screen protector from one edge, peel it back to the last bubble then re-fix the protector in place by slowly apply pressure across the proctector as you push the protector onto the display making sure no bubbles forms between the display and the protector.
Dec 28, 2011 | Apple iPad Tablets & eReaders
Screen protectors - nintendo ds lite
Be sure to thoroughly clean the screen then slowly lower the plastic slip and your done! after its on peel back the extra bit and then brush with a cloth.
Dec 19, 2007 | Intel Deluxe PC Camera CS330 Webcam
Hori Protector  for Nintendo DS Lite Logo
Top Hori Video Game Consoles & Games Experts
James Wishart
Are you a Hori Video Game Console and Game Expert? Answer questions, earn points and help others
