Question about Pioneer HDJ-1000 Professional Headphones
Plastic connecting left headshell broke apart
When removing headphones from my head, under no pressure the plastic connecting the left headshell broke apart at the lowest knuckle, and I was wondering if this can be fixed, there just taped together at the moment??
  • Pioneer Master
  • 5,158 Answers
If the tape holds it in place then I suggest a good brand of superglue might hold on for a time. The only other cause of action I can suggest is visiting a Pioneer service center and seeing if the part is still made.
If all else fails have a look at the bottom of my tip on repairing dodgy cables and plugs, there is a suggestion on what to do with a broken headshell.
Posted on May 12, 2010
  • tmcostello Feb 22, 2011
    I have written an in depth solution to this problem. Hope this helps!
    http://teeseedesign.wordpress.com/2011/0...
  • 24 Answers
Check here to find the spare part you need:
http://artaudioparts.com/category/pioneer-spare-parts/hdj-1000-spare-parts/
I am not sure which part you mean in your description, but if it is the left hunger here it is:
http://artaudioparts.com/product/wnk3782/
Posted on Dec 19, 2013
The left ear phone broke and just dangles. Looks like part of the black plastic broke. Doesn't look fixable except by tape. Yuk. Tina
Take your headphones into the nearest Bose Audio store. Depending on the amount of time you have owned the headphones, you may be able to get a replacement or a discount on new headphones.
May 03, 2011 | Bose Audio Players & Recorders
Opening bose on-ear headphone speaker's cup
Apparently there are screws hidden in the small foam ring covering the plastic (not the earcushion). Try it removing the foam and tell me how it goes!
May 02, 2010 | Bose in-ear headphones - Black with...
Can I take apart the logitech A-00006 headphones easily.
The padding comes of easily, hook your finger under from the inside and push out gently. Once removed reviles 2 philips screws. Once they are removed you have to pry the 2 plastic disks that form the swiveling ear piece apart. Then you have access to the speaker, which is glued down with a still very sticky substance but will come up quite easilly, then remove the screw from directly under the center of the speaker, then you can pop off the swiveling earpiece that is on a kind of ball and socket joint, this took quite a bit of force. This is as far as i'm going as I now have access to the damaged part of the wire! And also the 4 screws mentioned in the original question. Hope this helps.
Dec 08, 2009 | Logitech Bluetooth Wireless Headphones
Head phone jack
Flip the Sansa face down with the headphone jack to the left. Take the cover off the battery then remove the 2 screws by the sync port. This frees up the plastic that covers the last screw. But before you can remove this piece you need to lift the 2 black tabs in the middle and slide your nail between the seam between the black and silver areas near the hold button. The rest comes apart easy or the couple I have fixed the headphone jack have.
Jan 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Cd wont stay in
Unfortunately it is broken. Hopefully it is under warranty. I have the same issue, and I took my player apart. There is a fracture in the back left corner on the piece that holds the cd clamp up. It is plastic and can not be easily repaired. You need to contact the company, or the retailer you got it from to get it fixed. Pics to follow..
Aug 07, 2008 | Dual XDVD8181 Car Video Player
Fellows ps60c-2
took schreder apart: The plastic driven gear it striped is that gear serviced
Apr 01, 2008 | Fellowes PS60C-2 Shredder
How to take apart
I figured out how to remove the headphone clip without causing cosmetic damage to the headphone casing. Unfortunately for me, this was after I had scratched up the casing already. Anyway, to avoid the cosmetic damage, use some kind of plastic tool, like a plastic spoon. After pulling off the headphone cushion, you will see the aforementioned 4 slots. Carefully slip the handle end of the spoon underneath one of the slots(not through them), and apply gentle pressure toward the center of the speaker. Do this for each of the 4 slots, and the tabs should easily come loose. Hope that helps.As for figuring out how to get the headphone to work, I'm waiting for that solution myself. The right headphone is out, but the left one works, none of the wires are loose, so the damage must be from my nephew being careless with the headset cable, and probably tugging on it once too often. Don't let your 15 year olds use your headsets, if they tend to be clumsy :)
Mar 22, 2008 | Logitech 350 (980374-0914) Headset
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Pioneer HDJ-1000 Professional Headphones Logo
262 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
