Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
My dell c521 wont start i have green power light on and number 4 is light up green the fan is also running high
  • 3,940 Answers
Pretty Much General basic troubleshooting.
  1. Disconnect all external connections except the power, see if error changes. If it does, connect items 1 at a time till issue is isolated
  2. Remove all Expansion cards, see if any change
  3. Disconnect all drives from MB and power supply, see if any chage.
At this point if nothing has changed, replace the motherboard.
Posted on May 11, 2010
I can hear the fan running but wont turn on
Cmos ng, motherboard ng, bad peripheral, bad memory, power supply?
Start checking.
Jan 08, 2016 | Dell Dimension C521 PC Desktop
Dell optiplex 380 won't turn on
steve it can be many things.3-4 but you don't give enough information
Apr 03, 2013 | Dell OptiPlex 380 MT Desktop Computer...
It will not start even after I replaced the power
Before anything else, open your case and make sure all power and data cables going to motherboard, disk drives, etc are firmly seated, and remove and re-install memory sticks in the same locations. Sometimes temperature changes inside the PC can cause these connections to loosen. If that doesn't fix it, do you hear the noise of the cooling fans coming on? If you do, check your monitor for a green light. If you get a green light on the monitor and fans are powered up and running and you get nothing else it could be a hard drive issue. Try booting from CD in that case. If fans come on briefly and then shut off, or fans stay on and you have no green monitor light, this could indicate an issue with your processor or motherboard.
Jun 04, 2010 | Dell Dimension C521 PC Desktop
Dell C521 Power Issue
I would replace the power supply and if that does not help (after battery replacement and power supply), the ram could be faulty but usually faulty ram will beep a code. If ram has no avail i would suspect the mainboard and replace. Good Luck
Nov 24, 2009 | Dell Dimension C521 PC Desktop
I have a dell C521 tower,switch it on but light stays on orange,fans work but it wont switch on.help.
if the light remains Orange, Possible In Standby/Sleep/Hibernate Mode.
Try pressing And Holding The power Button For 4-5 seconds Or more.
If this Fails, remove the power Cable, remove side-panel ( Unless Warranted ) locate the silver cmos battery, on the motherboard. remove the battery for 10 seconds, replace and repower and startup. failing this i,d suspect the ram/memory or cpu.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension C521 PC Desktop
Cannot start up the dell c521, fan is loud and light is orange.
What you are describing is a no post failure. Disconnect all external devices, see if anything changes. if not, replace the motherboard
Oct 28, 2009 | Dell C521 DimensionTM PC Desktop
My dell dimension C521 has number 3 & 4
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/tshoot.htm#wp1064555
This gives you a list of every possible fault on this machine! It looks like you will have to contact DELL directly on this one!
Oct 19, 2009 | Dell Dimension C521 PC Desktop
Dell c521 won't start
- disconnect the hdd and optical drive cables, remove the expansion card, reseat the atx and 12v cable and turn the computer on. if the power led is glowing green connect the devices on by to find what device is causing the no post issue. after the strip down if the power button is still yellow replace the motherboard
Dec 06, 2008 | Dell Dimension C521 PC Desktop
Motherboard change
jethro..
http://support.dell.com/support/edocs/systems/dimC521/en/SM_EN/tshoot.htm#wp1064555
check on system lights... what are the diagnostic lights telling you??
if the 4 lights are off you may have a problem with the led itself or the powersupply is just messing with your head.
Dec 02, 2008 | Dell Dimension C521 PC Desktop
Amber Light and fan running
1st thing, disconnect everything but keyboard mouse and monitor, see if anything changes.
If the issue persists, ensure that all power and card connections for the motherboard are tight and secure. If you've added RAM or other parts, remove them. Reseat the RAM in the motherboard that came from Dell.
If none of those ideas have any effect on the issue, replace the motherboard.
Jul 01, 2008 | Dell Dimension C521 PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
133 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
