Question about Barbeques Galore 52-inch Grand Turbo 175800 (NG) Grill
Flame loses intensity when propane cylinder is half full.
  • Barbeques Ga... Master
  • 2,871 Answers
Check the reg is giving full pressure
Posted on May 16, 2010
How do I adjust the flame on my Weber gas grill
turning the knob adjusts the flame intensity
it is not doing that and the flame is very low
low gas in the cylinder
regulator
blocked jet for the burner
Nov 19, 2017 | Weber Grilling
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
Our Weber is working fine on full power but as
Try replacing the regulator and hose, easy to do and not very expensive. If this doesn't work, please let me know.
Jul 11, 2010 | Weber Spirit? E-310 Propane Grill
I have full propane, yet a low flame?
check the burners are not blocked and the orffice , check the reg on the tank giving full pressure
May 15, 2010 | Thermos Stainless Steel Gas Grill
Flame is very low
take your burner out, an make sure theres no spider webs or nothing blocking the passage way of propane getting to the burner, check for rust, shake it, see if anything comes out, or it mite be time for new burner..
Mar 31, 2010 | Brinkmann 810-8410-S Stainless Steel...
Low flame on burners
Check the following items:
The propane regulator - and make sure the valve on the propane cylinder is all the way open
The fuel jets (the holes at the end where the propane comes out, usually brass)
The manifolds - they can become obstructed with insect nests
The gas burner valves
The burners themselves, again for obstructions
Apr 19, 2009 | Kitchen Ranges
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Barbeques Galore 52-inch Grand Turbo 175800 (NG) Grill Logo
Top Barbeques Galore Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
