Question about Kitchen Ranges
Oven door will not open after completing auto clean
  • Kitchen Ranges Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on May 14, 2010
How do I lock door for self cleaning
Some ovens have a latch handle between the top of the door and the actual range top that you have to push sideways to lock. May also be a lock button you have to push in while moving the latch handle.
If you don't see the latch handle, The lock system may be the hidden type that should lock automatically when set to clean. Once the oven is set properly for clean, a motor will latch the door by itself. After the oven gets close to clean temperature, the latch gets locked out and the door will not open until the clean cycle is complete and oven cools down to normal room temperature again. This is a safety feature so you can't open the door while the oven is at clean temp (about 850 degrees). Hope this explains enough. If door never auto latches, could be a problem with the latch/lock system and motor.
Mar 29, 2015 | Ovens
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
Oven door won't open after cleaning
The oven shut down before self cleaning completed without a model # this is what I can tell you the TOD thermal overload fuse opened cannot be reset if you have no display then the thermal cavity fuse opened buy a set of feeler gauges from the auto store take one go to top of door in the middle between between door and body push to left door should open.
Sep 24, 2014 | Whirlpool Ovens
Oven door latch will not release so that I can open the door
Try jiggling the door by the handle. Jiggle it hard, both sideways, in/out and up/down. The little piece in there that releases the door may just be stuck, and didn't move quite far enough to let the door open. These things happen.
Nov 28, 2013 | GE Profile JTP18 Electric Single Oven
Maytag Frigidaire Electric selfcleaning oven slide in type 30 inch wide purchase in 2003 --cleaning lady cleaned oven,unable to pull open oven door -door is jamed shut ???
Hello
Let oven completely cool then try.Locks out for safety because of extremely high temperatures involved in self clean mode.
Feedback appreciated
Aug 05, 2011 | Frigidaire FEB24S2AS Single Oven
Oven won't work after cleaning
Molly,
"Auto Clean" means that the control thinks the door is locked. If you can open the door, it's obviously not locked. You can try turning the power off at the breaker. Leave it off for 20 minutes or so. See if this resets the control. If not, the high temps in "auto clean" may have fried one of the monitor switches on the door latch.
Let us know what happens.
SG
Mar 26, 2009 | GE Ovens
I CAN'T UNLOCK MY OVEN DOOR!
First get rid of the noise by turnining off te breaker.
You will have to pry the lock open.
This is common I use a small screwdriver and coathanger wire,then pull out oven enouhg to replace lock.
Mar 12, 2009 | Ovens
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Maytag stove will not open after cleaning
is the oven completly cooled down? the latch is hat sentisive the oven must be cool before the latch will open this can be from 15 min to 2 hours after the clean cycle is complete
Aug 25, 2008 | Maytag MEW6630D Electric Double Oven
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Kitchen Ranges Logo
71 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
