Question about Kenmore 63942 Dryer
Dryer not working
Dryer works for a few minutes then stops.
  • MAGNOL Mar 30, 2008
    IN TIMED DRY, DRYER RUNS FOR A WHILE, THEN WELL BEFORE FINISHING, THE TIMER ADVANCES TO OFF, LEAVING A LOAD OF DAMP CLOTHES. HAS BEEN GOING ON CONSISTANTLY FOR SOME TIME
  • 943 Answers
THanks for the question For that problem i would check your venting Make sure its not pushed up against the wall Especially if you have the white plastic venting If your vent is blocked it will cause exactly that Thanks for the question The appliance doc
Posted on Sep 11, 2008
6ya staff
SOURCE:
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
www.hometips.com/repair-fix/clothes-dryer-stops-and-starts.html
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
I had a bunch of verywet towels because my sink was leaking, and I put them in the dryer and it worked for a few minutes them stopped. What might be wrong?
Good Morning Friend,
I understand that you had a bunch of wet towels, and put them in your Frigidaire dryer, model# FGQ332ES. I see that your dryer worked for a few minutes and then stopped. There could be a possibility that the wet towels were too heavy from all the water in them. I suggest that you spin the towels out in your washer first and then move them over to your dryer. If you are still noticing the dryer working for a couple of minutes and then stopping, I suggest giving your appliance a hard reset. You will do this by either unplugging your appliance or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored start it on any cycle. If your dryer is still shutting off after a few minutes, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off after a few minutes. Hope this is helpful.
-Best regards-
WP
May 14, 2014 | Frigidaire FGQ332ES Gas Dryer
LG ELECTRIC DRYER DLE2516W: ONLY ON DELICATE SETTING, CYCLE STOPS AFTER ONLY 5 MINUTES?
if this stops after only a few minutes and all the other cycles work fine then u have a faulty control board which tell the unit what to do
Aug 21, 2009 | LG DLG5988 Gas Dryer
Dryer stops after a few minutes Siemens WTXL2101 EU/07
Maybe a sensor at the back sensed overheating. You might be able to remove the backplate and search for a little button, which acts as some sort of reset button. (I do have a different tumble dryer, but it's the same brand and had similar problems). Maybe more ventilation is needed to prevent this from happening again.
Mar 28, 2009 | Siemens WT79020EU Electric Dryer
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Whirlpool tumble dryer stopped working , took 1 load out put another load in and just stopped
check your dryer door switch, common for strike actuator to break off, not recogniziong door closed the machine will not do anything. if that sgood yo may have blown a thermal fuse
Nov 05, 2008 | Whirlpool Dryers
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Dryer starts to work and then stops working after a few minutes
doesn't usually happen so quick but may be a blockage in the air duct. take top off. if i remember right, duct runs across the back to the dryer fan. check for lint build-up. if poor air flow, an overheat stat will cut off the dryer
Apr 02, 2007 | Indesit WA 125 Front Load Washer
Kenmore 63942 Dryer Logo
41 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
