Question about Vizio GV47LF Television
When turned on ,nothing comes up,no picture
When we turned the tv on ,there is display ligt,but does not retrieve picture,is it the power supply or the invertors
    Problem Solver:
  • 11 Answers
There is a connection between the inverter and the powersupply. on this connector there should be a line that supplies 24 volts. if you are getting that 24 volts on a volt meter the you are most definatly looking at inveters. if you dont powersupply. just a warning if you have 24 volts and the inverter doesnt work you need a new lcd panel, which is not worth buying if you can find one
Posted on Feb 14, 2011
The unit comes on using the power button as well as a remote and displays "Polariod" on scrfeen and then nothing else, no sound no picture?/
More than likely your power supply needs two electrolytic capacitors, 10MFD @ 450 WVDC. If you find the capacitors on the power module to the top of the metal enclosure inside the tv, they will probably appear to have swollen tops.
Mar 01, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Lcd tv turn off while running condition but red ligt is still on
FAULTY POWER SUPPLY DUE BAD OR BULGED CAPACITORS
UNDO THE BACK I INSPECT THE POWER SUPPLY
THE POWER SUPPLY LOOKS LIKE THIS :
: http://pictures.kyozou.com/pictures/_12/11729/11728602.jpg
REPLACE THE BULGED CAPACITORS, MAKE SURE THAT REPLACE FOR THE SAME ONES.
IF NOT WORK, REPLACE THE ENTIRE BOARD (google it for u)
https://www.google.com/search?sugexp=chrome,mod=19&sourceid=chrome&ie=UTF-8&q=JVC+LCA90796+LT-42X579+POWER+SUPPLY
HOPE 2 HELP
www.bostonrecycling.net
Jun 30, 2012 | JVC LT-42X579 42 in. LCD TV
Sound but no picture
Hello!
Does sound comes out of TV speakers? Or you have "home theater" hooked up to?
In first occasion: TV turns on, stays on, display blinks once, then nothing?
Inverter is at fault. Second occasion: TV turns on, stays on, display glows dark, sound OK, no picture: T-con board at fault. Third occasion: TV turns on, shuts off, sound is coming through "home theater"-OK. Power supply or inverter, or T-con are at fault. TV need major diagnostics and repair in every case. Let me know if you can handle that. Will guide you through the process.
Thanks,
Alex.
Dec 15, 2011 | Toshiba Televison & Video
D61W20 61 in. Rear Projection Television: turn on tv ligt blinks 3 times and goes out....
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected this
is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Apr 28, 2010 | Televison & Video
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Tv wont come on
You may have some type of short INSIDE of your TV .Your TV is trying to turn on and RESETS itself to try again. If you have an EXTERNAL [black box],(usually means power supply, power adapter,etc.) power supply, that!! could be at fault. not giving the proper voltage, current, causing the machine to fault. If you can exchange a known working power supply to see if that is the problem.
If you don't know what you are doing, don't go inside of the TV. There are circuits that can hold a charge of electricity that can & will hurt you.
Oct 25, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
No picture ; no sound
the red blinking light usually has a pattern that gives you a code to the possible problem.
Maybe you have a bad power supply board. You have to open the panel and do a few tests on the power supply's outputs to be sure.
It produces a variety of voltages for different parts of the tv ie. the plasma display panel and the audio system. The components supplying power to the audio system may have failed a year ago and recently the pdp.
plasma tv's are expensive to repair, most of the time you can get a better tv for the same price. You can reduce that cost by learning and troubleshooting it yourself.
Feb 23, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Vizio GV47LF Television Logo
412 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
