Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
Remote does not work
Can the "input" be changed without a remote control through some combination of buttons, or otherwise? Thank you
    Champion:
  • 222 Answers
Take off your batterry open your remote control, there are 4 phillips screw at the back, you will see a brown circuit board take that off ,on the other side of the circuit board, (one that is painted green) clean that surface with a piece of cotton slightly wet with a rubbing alcohol, and clean the black carbon thingy on your remote pad as well, make sure that they're both dry, then replace your remote with a new battery this'll work
Posted on Jun 05, 2010
Change emerson tv input without remote
As there is no menu button at the front panel of this TV, there is no way to select its input selection, without a remote control. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 02, 2013 | Televison & Video
Insignia ns27rtv can not change input without remote
As there is no menu button on the front of the TV, you must have its remote control to select he inputs.
Jan 11, 2013 | Insignia Used Original NS27RTV Remote...
Chanel button changes input
Try 124 code, might work for combo unit.
Aug 19, 2012 | Innovage Jumbo Remote Control
My HDTV, 42", won't turn off, change
Check the tv manual control buttons right side of the tv bazel frame tv facing u,see if u can used the buttons like power, chanels - + or volumes - + from it.If u can, mean the tv have problems with is remote control.Change new batteries for the remote,still no response from the remote.Mean the remote is dead.Try website like Remotes.com to buy an exact remote or very close it.
Jan 17, 2011 | Sylvania LC420SS8 LCD TV
Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Aug 17, 2009 | Directv RC-64 Remote Control
New remote won't program to switch to cable input.
That's a problem with universal remote controls. Often they don't control every function of the TV. They just don't have the buttons needed to control everything the original remote did. You'll have the most basic controls - power, channel and volume up and down - and maybe a menu button. But you'll frequently find other things don't work, like switching inputs. There isn't anything you can do except try all the codes for your TV brand and see what each button does. You might find that the buttons have different functions depending on which code you've entered. You might also look for another brand of universal remote that has more functions available.
May 23, 2009 | Daewoo Televison & Video
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
How does one change the video inputs without the remote control?
If you have lost the remote, go to any electronics store and buy a universal one. I have programmed many generic remote controls, and they all work fine for adjusting the video inputs. Not all television sets allow their video inputs to be switched without the remote. Most likely you will have to buy a replacement.
Jan 08, 2009 | RCA Scenium L50000 Television
No Remote - Need to access Menu
on some sets you can push both the channel up and down buttons to access the menu, then use them and the volume buttons to navigate the menu. otherwise you may have to get a programmable remote control.
May 30, 2008 | Televison & Video
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
217 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
