Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic 50 inch lcd
I have a visible green line on the top right side of the tv when its ON
  • Anonymous May 16, 2008
    multiple thin, assorted coulour lines down the screen, top to bottom.
    Genius:
  • Panasonic Master
  • 1,673 Answers
This may be a screen addressing fault, or a driver fault, possible bad ribbon cable, cold solder connection in the screen drive or processor, or the screen itself may be faulty.
The set would have to be properly diagnosed to know the exact failure, and the necessary parts changed.
Jerry G.
Posted on Apr 30, 2008
I have a 2011 Panasonic plasma tv I bought new in 2011 and today there is a red/blue stripped line 1-1.5 inches wide across the top and a dotted green/purple line 3-4 inches below the blue/red line.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 17, 2017 | Panasonic Televison & Video
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 17, 2016 | Sony XBR Televison & Video
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Green lines down length of screen on my samsung 40 inch LE40F8
The reason for the green lines are the resolution. I'm assuming you're TV is set at 1080i, not 720p or 1080p correct? What happens is the "i" stands for interlaced, meaning, your TV displays your images with scan-lines. The "p" stands for progressive, meaning, TV displays picture as a whole. You can not visibly see the scan lines when seeing 1080i, but certain TV programs are not outputting their show to the resolution you're at, which will cause you to have the green line up at the top of your TV. SOME TVs might let you adjust the settings to rid yourself of the scanline, but most consumer TVs will not let you without the maintenance code to protect your unit from over calibrating and braking your television. Hope this helps.
Mar 20, 2010 | Samsung LTN1535 15 in. HD-Ready LCD...
Thin vertical red & green lines in upper right of 42 in sanyo lcd
More than likely your control board. Available at www.partstore.com Cost could be between $130 and $200. Not that complicated to install if you can use a screwdriver and are careful. Let me know how this works out.
hardrocko
Feb 01, 2010 | Sanyo DP42848 LCD TV
Yellow discoloration on screen
the screen is yellow green color all the we have had it worked on once already does anyoblemne have any comments on how to solve this problems?
Jan 27, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Problems with 50 inch flat screen Panasonic
Yes there is a way to work with formatting your Tv. On your controller go to menu and settings and look for display. you can change where the words display. Bring them up or down. The lines, I'm not sure about. are all your connections nice and tight?
Jul 31, 2008 | Panasonic Televison & Video
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
71 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
