Question about Sony PlayStation Portable (PSP) Console
I need help please
I turn my psp on go to the place where you can see how many hrs left and charage level and power souce battery, at the bottom of the screen there is a little "o" Back .....i push "o" but nothing happens. this also happens on other places and my game. Can you help me? Thanks
  • Eileen Lopez
    Eileen Lopez Apr 14, 2008
    I am using the charger it came with and battery is charged up. When I try to put my name in the name "john" is already there. I try to delete, but to no avail. Just sits there and will not delete
    Problem Solver:
  • 15 Answers
Are you using a different charger? if not than get a cheep used battery or a new one ok?
Posted on Mar 29, 2008
Why when i switch on my psp he cannot read my memory card and he will not turn on?
Hi p_demain,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, it needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 15, 2011 | Sony PlayStation Portable (PSP) Console
My psp is not working because the charger is fried or its the psp itself and doing it.And I just got a brand new charger on last saturday too.And i was in the middle of a important level.And I LOVE monster...
Plug the psp in with the charger and remove the battery. If it turns on, then the battery may be no good.
If it dies not turn on at all, then the charger or batter is bad.
If it turns on with what little power you probably have left, it is the charger.
If you have a friend with another psp and charger, test it with his. If it is not getting power at all, then its something with the psp that you do not even want to deal with.
May 15, 2010 | Sony PlayStation Portable (PSP) Console
No screen is coming on psp
Turn the PSP off and remove the battery and battery cover. Remove the two screws underneath the battery. Remove the other two screws on the opposite side of the battery. Remove the final screw on the bottom edge of the PSP.Grasp the PSP on both sides with each hand and pull the cover off of the PSP. Locate the button bar on the bottom front of the PSP. Use your flathead driver to lift up the left side of the button bar until it pops up off the LCD support. Lift the button bar cable tab upwards to remove the cable and remove the button bar.Insert your flat driver into the small space on the left side of the LCD screen between the the LCD housing and the LCD mounting bracket. Twist the screwdriver slightly and the mounting tabs will pop out. Gently remove the other side of the LCD after popping out the first side tabs. Bend the PSP screen all the way down until you can see the backside of the screen.
Lift up the flex cable connectors and unhook the cables that connect the screen to the PSP motherboard. The tabs are brownish in color; they are very fragile, so be gentle. Lift the PSP screen out of the housing and place to the side.Place your new PSP screen into the PSP, face down like you had the older screen after popping out the mounting tabs. Connect all of the cables from the PSP screen into the motherboard tabs. Fold the screen back into the bracket, snapping it into place. Place the button bar back onto the LCD support, connecting the last cable. Place the cover back onto the PSP and tighten screws to finish.
Apr 15, 2010 | Sony Video Game Consoles & Games
MY PSP WONT ON EVEN YOU WILL CHANGE ITS BATTERY
Apr 12, 2010 | Sony PlayStation Portable (PSP) Console
Nothing on the screen when psp is switched on
Apr 02, 2010 | Sony PlayStation Portable (PSP) Console
How to fix my psp the screen wont turn on
Problem loading the NEW PSP ACTION REPLAY.
TADA! answer 4 u.
It's your battery. Take out your battery from the psp and look on the back of it. If, at the top, it says PSP-S110 and at the bottom it says made in China, be bummed. That's what mine said and the codejunkies website warns about that battery. Dunno where to get a new one though. Hey, diagnosing the problem is half the battle. Good luck.
Dec 03, 2008 | Video Game Consoles & Games
Mge nova avr 1250 problem
ups charged for 8 hrs .No alarms but on powerfail no output to connected device
Nov 15, 2008 | Computers & Internet
Psp 2006 battery
You don't have a problem; the seller is an idiot. Leave it plugged in for good measure, but your PSP is fine.
Many products ship with a completely discharged battery (many cellphones, for instance) and they must charge for a long time. PSPs don't; they ship with a partially charged battery.
Dec 05, 2007 | Sony PlayStation Portable (PSP) Console
PSP Won't turn on
Try this>
Start with the PSP turned off. Press and hold the R button when your turning on the power. Turn it off again, then back on. Sometimes this works. If not, your PSP is probably Bricked.
This means that you done something to interupt an upload or program in progress. The eeprom program is corrupted and the PSP will not boot up. The term Bricked, refers to your PSP being no better than a black Brick paper weight. I have heard of a repair for this called Pandoras Battery. I am not sure if the Pandoras battery really works to restore Bricked PSP's. It may be worth a try for you to take a chance on Pandoras Battery.
Nov 07, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
