Question about Agri-Fab Agri - Fab Snow Blower - 42"
Accurian mp3 42-198 wont turn on
Accurian mp3 42-198 wont turn o. I charged it and disconnected it via the safe way to disconnect usb. Then I went to turn it on and it said something about connect to pc to solve problem. Then I tried to turn on again to read the problem again and it wont turn on.
How to fix H350 Bluetooth headset? why wont it charge?
You should charge it via wall charger so it charges faster.
Jun 26, 2014 | Motorola Mobility Bluetooth Hands Free...
My sons otek aqua W500 DCS-5D8 Waterproofcamera wont turn on?
My granddaughter's red Otek W500 DCS-5D8 camera (Christmas gift) has an identical problem
Dec 30, 2013 | Sakar 92022 VGA Digital Camera - Star Wars...
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
The player comes on when connecting USB but has no power when disconnected and it is new
Hello Chris,
The battery could be drained and needed to be plugged into usb to charge. In here, the computer is the one supplying power to the MP3 player so it turns on. Try charging it further like one hour before you take it off. Also, please remember that all USB devices, especially mp3 players should be "safely removed" to avoid it being fried. To safely remove, click on the green usb icon on your lower right corner of your computer and click "safely remove device..". Wait until it tell you that it is now safe to remove your usb device.
Now if it still wont work, the player might be defective and since it is still new, please dont hesitate to return back and ask for replacement as this player might give you other problems later on. Since it is under warranty it would save you further cost.
Oct 27, 2009 | Curtis MPK2066 MP3 Player
I have had my Sony walkman NWZ-E436F for about 3
Hey... I know this thread is fairly old... but I will tell you what I did. I have the Sony MP3 walkman,NWZ-E438F.. Until recently I have had no problems just disconnecting, I had no way of sagely ejecting. Yesterday, I tried disconnecting, and the screen started flickering and and saying that it was still connected... and that was all I got... so I left it plugged in till this morning. I went to Sonystyle.com.
At the top of the screen, find where it says support, click on online product support. When it brings you to the next page, you will see an area where you can put your model # right to the right of all the icons. Enter your model number found on the back of your device and press enter.
On the next page toward the top, you will see a link under Drivers & Software. Click on that. Select your operating system on the next page, select firmware and follow the steps... It really said I was upgrading from a current 1.02 to a new 1.02, but after it was done, the screen on my MP3 Continued sayin do not disconnect, and I was able to "safely" disconnect my device buy right-clicking that Icon in the bottom right hand corner of your PC.
That is the only time you have to disconnect in that fashion... once you plug it back in again, you can disconnect as you did before, by just unplugging. But now mine is Fine.
Oct 21, 2009 | Sony NWZ-E436F MP3 Player
My rca mp3 wont turn on
1 have it into usb device
2 hold down the play button.
3 update the firmware from RCA website.
Jan 10, 2009 | RCA M4204 MP3 Player
Accurian Won't Turn On...
When I turn on my Accurian MP3 Player, it says connect to PC and go to Device Manager, I dont know where the process is
Jan 07, 2008 | Audio Players & Recorders
How to correctly disconnect maxtor 500 gigabyte external hd
Hi, Normally the steps would be: 1. In your PC, in the System Tray, click on the "Safely Remove Hardware" and then on the "Safely Remove USB Mass Storage Device-Drive(?); 2. Unplug USB cable; 3. Power down external device. Hope this be of some help/idea. Good luck and kind regards.
Sep 17, 2007 | Maxtor OneTouch II external hard drive...
Agri-Fab Agri - Fab Snow Blower - 42" Logo
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
