Question about Microwave Ovens
GE microwave error - PROBE
I have a built-in GE microwave, circa 1994. Never had any problem with it until now. The display reads PROBE and the touchpad no longer responds. If I switch off the power to the unit for a day, the problem is corrected and the microwave operates normally for about a day. Then PROBE reappears on the display with the same unresponsiveness of the touchpad. Any ideas?
  • vchad Apr 02, 2008
    Thank you! Yes, this is a very helpful solution and is very likely correct. I will follow your suggestion and test troubleshoot the keypad. Thanks!
  • Microwave Ovens Master
  • 9,086 Answers
Chances are the keypad (membrane switch) is shorting, or the control panel as an assembly may need repair.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. It shows you how to test the keypad.
Also, we repair these for $39.95 (in most cases) for customers nationwide via mail. If yours needs a keypad, we could also give you the estimated total repair cost if you contact us with your exact model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
GE Spacemaker II clock not working (1994)
Are you working with the owner's manual?
You can download GE owner's manuals and installation instructions here.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave with the message sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Thanks.
Jun 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven is displaying sensor error
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Nov 19, 2008 | GE JE620 Microwave Oven
GE microwave model jes1456 has sensor error
Aug 23, 2008 | GE Microwave Ovens
Runs whenever door is shut, displays "8 lo code", can't cancel
This is usually a shorted keypad or a problem on the control board.
We regularly repair these for customer nationwide for only $39.95, plus parts cost if a keypad is needed.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Looking for Temperature probe for JVM1190
Most any standard microwave temperature probe should work, from places such as Wal-Mart, Home Depot, Lowe's, etc.
Nov 21, 2007 | GE JVM1190 Microwave Oven
Microwave Ovens Logo
262 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
