Question about Car Audio & Video
I get the error code e20 whenever i try to put a burned cd in it. some of them work and some not at all. can you help
  • aldude345 May 11, 2010
    Thank you so much teran. great help and you answered my question better then anyone could. :)
  • 10,515 Answers
Kindly tell me the Make and Model of the Stereo?
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 11, 2010
    oh sorry its a 99 Pontiac grand dam se
  • taran_2005
    taran_2005 May 11, 2010
    Thanks for your response!!
    There is a Technical Bulletin issued for this Model explaining the Cause and the Fix. The Technical Bulletin is :-
    Subject: Information on Error Codes on Radio Display -- Their Cause and Corrective Action
    Models: 1995-1996 Buick Roadmaster
    1995-1999 Buick LeSabre
    1995-2004 Buick Century, Regal
    1995-2005 Buick Park Avenue
    1996-1999 Buick Riviera, Skylark
    2004-2005 Buick Rainier
    1995-1999 Chevrolet Lumina, Monte Carlo, Fullsize Pickup Models (Old Style)
    1995-2005 Chevrolet Blazer
    1996 Chevrolet Lumina APV
    1996-1999 Chevrolet Cavalier
    1996-2000 Chevrolet Express Van
    1996-2002 Chevrolet Astro Van
    1997-2002 Chevrolet Camaro
    1997-2003 Chevrolet Malibu
    1997-2005 Chevrolet Corvette, Venture
    2000-2005 Chevrolet Silverado
    2002-2005 Chevrolet Avalanche, TrailBlazer, TrailBlazer EXT
    2003-2005 Chevrolet SSR
    2004-2005 Chevrolet Classic, Colorado
    1995-1999 GMC Fullsize Pickup Models (Old Style)
    1995-2002 GMC Jimmy
    1996-2000 GMC Savana Van
    1996-2002 GMC Safari Van
    2000-2005 GMC Sierra
    2002-2005 GMC Envoy, Envoy XL
    2004-2005 GMC Canyon, Envoy XUV
    1995-1999 Oldsmobile Aurora, Eighty Eight
    1995-1997 Oldsmobile Cutlass Supreme
    1999-2004 Oldsmobile Alero
    1998-2002 Oldsmobile Intrigue
    1995-1996 Oldsmobile Ninety Eight
    1996-1999 Oldsmobile Achieva
    1996-2004 Oldsmobile Bravada, Silhouette
    1995-1999 Pontiac Bonneville, Sunfire
    1995-2002 Pontiac Firebird
    1995-2005 Pontiac Grand Prix
    1996-1997 Pontiac Trans Sport
    1996-2000 Pontiac Grand Am
    1997-2005 Pontiac Montana
    2003-2005 HUMMER H2
    This bulletin is being revised to update model years and vehicles as well as update the information. Please discard Corporate Bulletin Number 01-08-44-005 (Section 08 -- Body and Accessories).
    Starting in 1995, the family style radios, as well as the 12-disc LLAI and 6-disc LLAI (Low Level Audio Interface) changers and the 10-disc FMI (FM Interface) changers, have error codes to help diagnose playback mediums.
    Some systems will only have an ERR message and no other indicator. If an ERR message is encountered without any other identifier, you may review the following error codes to try to determine the cause of the error and correct it before sending the unit to the authorized service center. If ERR or E (and a number) appears on a customer's radio display, the number may give you a clue to the problem and corrective action.
    Below is a list of code numbers that may appear on the unit.
    Important: Not all family radios have these codes. They are dependent on the model year.
    Cassette Errors
    E10 or TIGHT TAPE: Tight tape error
    Cause(s): A restricted cassette tape transport or broken cassette drive belt
    Correction: Substitute a different cassette tape. If there still is an error code, service the unit at an ACDelco® Service Center.
    E11 or BROKEN TAPE: Broken Tape Error
    Cause(s): A broken cassette tape
    Correction(s): Substitute a different cassette tape
    E12 : Communication Error
    Cause(s): A vehicle/radio communication problem or an internal radio communication problem
    Correction(s): Disconnect the battery voltage to the radio then reconnect after a few minutes. If there still is an error, service the unit at an ACDelco® Service Center.
    E13 : Tape Communication Error
    Cause(s): The micro-processor is reading the speed pulses from the tape deck either too fast or too slow.
    Correction(s): It the tape player is still playing a cassette, try a new cassette. If there is still an error, service the unit at an ACDelco® Service Center.
    E14 or WRAPPED TAPE: Wrapped Tape
    Cause(s): The tape is wrapped around the capstan. This means a tape is wound up in the tape player. This error message could appear when a CD adapter is being used. Other causes could be old or damaged tapes. Long playing (90 or 120 minute) tapes are thin and can stretch easily creating this condition.
    Correction(s): Try playing a known good quality tape. Remove the CD adapter.
    Cln Tape Indicator
    Cause(s): This message appears after 50 hours of accumulated tape play.
    Correction(s): We suggest cleaning the tape head. Then reset the radio by depressing the eject button for five seconds. Cleaning the heads will not reset the "Cln" display. To reset the "Cln" display, push and hold the eject button for five seconds. The display will return to its normal display.
    CD Errors
    E20 or CHECK CD :
    Cause(s): The CD player cannot focus on the disc or there is an internal focus problem.
    Correction(s): Try cleaning the disc or using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity. If the problem is not corrected, service the unit at an ACDelco® Service Center.
    E21 or CHECK CD :
    Cause(s): There is a problem with reading the disc
    Correction(s): Try cleaning the disc or using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity. If there is still an error, service the unit at an ACDelco® Service Center.
    E22 or PLAYER ERR :
    Cause(s): The CD motor is not handling the compact disc properly.
    Correction(s): Service or exchange the unit at an ACDelco® Service Center.
    E23 or PLAYER ERR :
    Cause(s): There is a vehicle/radio communication problem or an internal radio communication problem.
    Correction(s): Disconnect battery voltage to the radio and then reconnect after a few minutes. If there is still an error, send the unit to an ACDelco® Service Center.
    LLAI CD Changer Errors
    E30 : Focus Error
    E31 : Tracking Error
    Cause(s): There is a problem with reading the disc.
    Correction(s): Try cleaning the disc or try using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity. If there is still an error, service the unit at an ACDelco® Service Center.
    E32 : Motor Error
    Cause(s): The CD motor is not handling the compact disc properly or defective magazine mounting screws are interfering with the mechanism.
    Correction(s): Reload the magazine. If there is still a problem, replace the magazine. If the problem continues, back out the mounting screws. If the condition is corrected, replace the screws with shorter screws or add washers to the existing screws. If this condition still exists, service the unit at an ACDelco® Service Center.
    E33 : CD Changer Communication Error
    Cause(s): There is a vehicle/radio communication problem or internal radio communication problem.
    Correction(s): Disconnect battery voltage to the radio and then reconnect after a few minutes. If there is still an error, determine if the problem is with the radio, the harness or the changer. Inspect for correct voltage at all connectors. If there is still an error, service the unit at an ACDelco® Service Center.
    E34 : Changer Door Open
    E35 : Changer Magazine Empty
    FMI 10-Disc Changer Errors
    E01
    Cause: This indicates a malfunction of the disc changer functions.
    Correction: Before sending the unit in for service, perform the following procedure:
    1. Press the reset button on both the changer and the remote.
    The reset button on the changer is located on the front panel of the unit. It can be activated with the tip of a pin.
    2. If the unit does not operate after resetting it, remove the magazine by inserting a business card between the magazine and the mechanism. The lock lever will disengage to allow the magazine to eject.
    3. Make sure all CDs are in the magazine and none remain lodged in the carriage. If, upon removing the magazine, a CD is found lodged in the carriage, remove all CDs from the magazine and reinsert the magazine into the changer.
    4. Press the eject button. This should cause the lodged CD to move from the carriage into the empty magazine. The magazine should automatically eject and normal operation will return.
    5. If the changer fails to resume normal operation, send the unit to an ACDelco® Service Center.
    E30
    Cause: Excessive temperature
    Correction: Let the temperature of the changer resume to the normal range.
    Thanks!!
Just recently, when i try to burn a CD in itunes, it starts burning the first song, then cancels and pops up with "an unknown error occured (4900)" Then, it freezes itunes until i manually eject...
http://www.pc-library.com/errors/error-code/4900-0x1324/ theres your answer please rate me 4 thumbs up for doing the research for you. I hope this explains everything! Have a wonderful day.
May 10, 2011 | Gateway GT5220 PC Desktop
E20 error code
E20  error is a problem with the focus on the CD reader.
If the error only occurs on one CD then it's most likely a problem with a smudge or scratch on that CD and not the CD player  lens .
Try cleaning the CD thoroughly with iso-propyl alcohol
Nov 06, 2009 | Car Audio & Video
What the E-20 showing on my cd player
Hello! The "E20" error code loosely means that the CD player cannot focus, or read the disc properly. This could be from a number of reasons, dirty pickup lens, dirty/scratched disc, excessive humidity, or using a burned/copied CD that was burned at a speed that was too fast to provide a "deep" enough burn to the disc. And lastly, I know GM's Delco radios in the late 90's had issues reading CD-RW's; but read CD-R's fine (if burned slow enough)
My first suggestion would be to see if this happens on all CD's - originals and/or burned ones. If it only happens on burned/copied discs - I'd recommend slowing down the burn speed to no faster than 16x and retrying. If it does happen with both types of discs, then I'd purchase a CD lense cleaner and run that through a couple of cycles.
Hope this helps and good luck! Thanks for using FixYa!
Sep 26, 2009 | 1997 Pontiac Bonneville
E20 code. Not draining
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
I have a 97 Buick Regal and I get a E20 error message:cd player
If the CD is over 60 minutes it will not play on domestic cars
May 29, 2009 | 1997 Buick.5 Regal
What does E20 code means on a delco cd player?
Hi E20 mean's
try a known good CD and if it still displays E20 then you will have take it to a radio repair shop
May 10, 2009 | 1997 Pontiac Sunfire
My sound stutters on my Dell Inspion 6400 whenever I put a DVD in
You are very welcome. I am glad I could help. Apparently what happens is that the drive takes errors and XP downgrades the transfer mode. Once that happens you will have flaky problems, another problem you will see when this has occured is when you try to burn a CD or DVD. It might burn for a while and then just towards the end it will fail.
Thank you for letting me know it worked.
Apr 05, 2009 | Dell Inspiron 6400 Notebook
Radio rejects CD's with an error code of E23
I checked my manual and could not find any results for an error e23, there is an error e20 for the reasons The disk is upside down
It is dirty scratched or wet
There's too much moisture in the air,wait about an hour and try again.
From presonel experiance these decks will not play MP3's only disks that have been burned using
the WAV. format.
Mar 25, 2009 | 1997 Buick Park Avenue
It's just an error message. It stands for Error 20. There is no way to fix the problem. It only reads cd's that it wants. But if it does play a cd, then suddenly stops, and says E20 and spits the cd out, it's most likely because the cd player got too hot. My car does that all the time. And it won't play a lot of burned cd's. Hope this helped.
Mar 24, 2009 | 1997 Buick.5 Regal
CD player will not work
I just got a grand am se.The problem is u have to have the sock stereo hooked up when u put a new one in.If it is ur stock stereo that has the problem there is a code that u can put in ita a anti-theft system. It's in da owners manual 3-14 i thinh.
Mar 04, 2009 | 2000 Pontiac Grand Am GT
Car Audio & Video Logo
192 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
