Question about Whirlpool RBS275PD Electric Single Oven
Oven door locked
My husband cleaned our oven with the self cleaning. The door was locked and would not unlock. He ended up cutting the lock. Now it says "door" and will not heat up now...am I going to have to buy a new oven? I like to cook...
  • 523 Answers
Change the lock assy
Posted on May 11, 2010
How to unlock oven Door frigidaire?
Usually the door locks during a self cleaning cycle for safety reasons. If the self cleaning cycle did not finish properly (over temp sensor trip, etc.) it could end up with the lock deployed or it could be that the locking mechanism failed in the lock position (unlikely!). Turn off the power to the oven by finding the correct circuit breaker in your electrical distribution box. Keep it off for some 30 seconds. If the oven is ok it will reset and unlock the door. If it has a failure in the locking mechanism you should be able to access that part from the top or you may have to call a repair person. Hope this helps!
Jan 20, 2016 | Ovens
My GE wall oven is stuck on lock mode. I cancelled a self clean (I know, big mistake) and after cooling down it still won't unlock. I've cut the power and still nothing. It's been 3 days! Trying to avoid...
Try putting it back in self clean. Listen to see if it locks. then cancel the self clean. It could be the self clean lock motor has gone bad. The lock hook can be moved to unlock the door by inserting a stiff wire like a coat hanger between the door and the oven and moving the latch over to unlock the door.
Nov 07, 2014 | Ovens
I started the self cleaning process with the timer, however, there was a light fire in the oven due to grease. My husband turn the oven (self-cleaning process) off by turning the circuit breaker off. ...
if the door is unlocked then clean all the grease and let go, if the oven is still locked then get a tech down to your house to have it unlocked since its not safe to have it run again with greaase
Sep 05, 2011 | Magic Chef 9512 Electric Single Oven
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
Oven door is locked shut. How do we get it to
Try cutting the power to it. ALSO push in to relieve the tension on the latch while attempting to open it.
Oct 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Locked door
Just inside the door but on the oven is a button. My husband pressed it and held it down while sliding the (center) lock to the left. That unlocked it.
Dec 31, 2008 | Ovens
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Whirlpool RBS275PD Electric Single Oven Logo
189 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
