Question about Gyration GyroMouse Pro
It doesn't work
I found a GyroMouse Pro in my classroom and installed it so I could walk around while teaching and still advance the powerpoint slides I am teaching off of. The green light on the base comes on when I plug it into the USB port but no light comes on the actual mouse. I have tried every combination of buttons I can come up with but I can't get the mouse to turn on.
Try opening the battery casing (slide the part that fits in your palm backwards) and making sure the battery pack is plugged in- I just got one off eBay and they apparently ship with the battery pack unplugged. just take the battery out (it's easier to plug in from a vertical angle) and connect the cables, if they aren't already, then put the pack back in. Replace the cover, then let the battery charge for 14 hours or until it stops blinking on the base. Then, restart/turn on your computer and it should work, or at least the light should stay on when you take it off the charging station...
Cheers
NInjaNumberNine
Posted on Jun 26, 2010
Corrupt data behind Powerpoint 2003 graphs
1. If you run PowerPoint 2003, choose Help, About Microsoft PowerPoint from the main menu bar. If the About screen doesn't indicate that you have SP1 (Service Pack 1) or higher, you should update your copy of PowerPoint. Choose Help, Check For Updates. When the Office Downloads page opens in your browser, click "Check for Updates" and apply the recommended hotfixes and/or service packs.
2. If you run Windows XP and have installed SP1, see Files open as Read-Only after installing Windows XP SP1, Other file/path related problems
3. Open a blank presentation (You can apply the template used for the damaged file, if applicable. That might help cut down on reformatting.)
4. From the main menu, choose Insert, Slides from File (or if you use PowerPoint 2007, Home tab, New Slides (bottom of button), Reuse Slides.
5. Try to insert slides individually if you're not able to insert the whole thing
6. Use software for restoring corrupt .ppt and .pptx documents https://www.repairtoolbox.com/powerpointrepair.html PowerPoint Repair Toolbox
May 06, 2015 | Microsoft PowerPoint Computers & Internet
Tip
How to convert PowerPoint to PDF well
<p><span>PowerPoint is playing a key role in the modern teaching classes. It's an effective way of communicating, teaching, and learning. With PowerPoint, teachers can show knowledge to their students easily as anything which conveyed through pictures will capture all our minds quickly and reside inside easily.</span><br /> <p><span> </SPAN><br> <p><span>But out of class, it is not easy for students to review lessons and it is too big for teaches to upload. No doubt, it is necessary to <a href="http://www.advancedpdfconverter.com/products/ppttopdf.html">convert PowerPoint to PDF</A> as PDF is very convenient for us.</SPAN><br> <p><span> </SPAN><br> <p><span>Converting PowerPoint to PDF well isn't an easy thing, For those free online conversion can't help you so much.. We may know that our PPT material contain pictures, formula, chart, hyperlink etc. Choosing a good PPT to PDF converter is important.</SPAN><br> <p><span> </SPAN><br> <p><span>I've personally tested Advanced PPT To PDF as following, and find it meet our requirement well.</SPAN><br> <p><span> </SPAN><br> <p><span><span>1.<span> </SPAN></SPAN></SPAN><span>First search <b><a href="http://www.advancedpdfconverter.com">Advanced PPT To PDF</A></B> and download it from it's official website.</SPAN><br> <p><span><span>2.<span> </SPAN></SPAN></SPAN><span>Install it in your PC and run it.</SPAN><br> <p><span><span>3.<span> </SPAN></SPAN></SPAN><span>Select your PPT files and add to the program, you can add large files at the same time.</SPAN><br> <p><span><span>4.<span> </SPAN></SPAN></SPAN><span>You can specify the output files, like location or add a password to protect your PDF files and so on. You can learn from the official website.</SPAN><br> <p><span><span>5.<span> </SPAN></SPAN></SPAN><span>Now you can enjoy your PDF study files made by yourself.</SPAN><br> <p><span> </SPAN><br> <p><span> </SPAN><br> <p><span>Actually, there are no many tools can help you convert PPT to PDF files well. If you try this program, you will find its brilliance.</SPAN><br> <p><span> </SPAN><br> <p><span>If you often need to convert Word, Excel to PDF or PDF to word, excel. You can Search <b><a href="http://www.advancedpdfconverter.com">Advanced PDF Converter</A></B>, It is 5 in 1 converter which provides you the best way to convert PDF to Word, Word to PDF, Excel to PDF, PPT to PDF</SPAN><br> <p><span> </SPAN>
on Jan 04, 2011 | Computers & Internet
Asus and PowerPoint will stall out only on the first slide
download and install the last version of Office suit pro app.
Apr 07, 2014 | ASUS Tablets & eReaders
How do I forward the slides of a powerpoint presentation using the remote?
Make sure that you connect a cable (usually the USB cable is supplied with the projector ) from the computer to the projector. Once communication is established, normal PPT slide advancing is done by pressing the up/down arrow keys (depending on the remote control layout)
Dec 18, 2013 | Epson Projector Remote Controller...
Which is the software that converts presentations into a self running slide show
there are many different slide show converters,
One of them with a free 30 day trial can be found here:
http://download.cnet.com/PowerPoint-Slide-Show-Converter/3000-2075_4-10385108.html
You need to have PowerPoint installed on your system when using the converter.
Success
Aug 29, 2009 | Microsoft Office PowerPoint 2007 Upgrade:...
Installing GyroMouse Pro on New computer with Vista
Since it uses a Microsoft or Logitech driver it should work.
It will probably plug and play install.
Sep 01, 2008 | Gyration GyroMouse Pro
Epson projector from computer & powerpoint
You need a wireless presentation remote that has a transmitter that plugs in to the back of the computer. This can be used to advance the slides. Make sure you get one that states the distance you need.
Let me know if that helps.
-Jeff
Aug 23, 2008 | Epson - PowerLite S1+ Multimedia Projector
Slide show dvd
Speaker's notes can turn a rambling presentation into one that's sharp and interesting. Check out this simple outline for teaching your PowerPoint students how to set up notes to improve their presentation delivery.Many PowerPoint classes focus exclusively on the fundamentals of creating and formatting slides, adding special effects, and running...
Jan 21, 2008 | Computers & Internet
Gyration GyroMouse Pro Logo
204 people viewed this question
Top Gyration Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
solver2010
Are you a Gyration Computer and Internet Expert? Answer questions, earn points and help others
