Question about Nikon Speedlight SB-600 TTL Flash
I dropped my sb600 and now the flash doesn't work. The unit comes on, but no flash. Is it worth fixing?
    Problem Solver:
  • 9 Answers
There is no harm getting it looked at
it may be something as simple as the bulb is broken and needs replacing rather then spending however much for a brand new flash
Posted on May 11, 2010
D90 dropped and caused a seal crack at front cover (cracked above lens mount). Build-in flash does not popup. It works well without flash. Do I have to replace the front cover? What should I do with...
The SB600 isn't made any more. I would recommend the SB700. Before you buy an external flash however, make sure that the hot shoe on you camera is still fully functional. An external flash is superior to the pop-up flash under almost any circumstances. Where your pop-up flash limits your shooting distance substantially, I have take pictures at night using an SB700 almost 100 feet from the subject and gotten correct exposure with my D90. Now there is one thing you will not be able to do without the pop-up flash, but I suspect it will never matter to you. You will not be able to use the pop-up flash to trigger the SB700 off camera.
Jun 14, 2011 | Nikon D90 Digital Camera with 18-200mm...
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
Canon d60 - Built-in flash will not pop up
There may be something obstructing it from popping open. Inspect the flash area carefully. You could remove the battery and put it back in to see if it corrects the problem. Also, check the flash settings in the menu to make sure that the flash is set to operate. If all of those fail then take the camera in for warranty repair. If the warranty has expired and nothing else works I would suggest getting an external flash for you camera. You will be amazed how much better your photos come out using an external flash. If you go that route then I would suggest going to a camera shop or department to make sure the flash will work for you before purchasing. If you just want a small flash a little better than the built-in, get the SB400. It's only around $125. The SB600 is much better, but will cost almost twice as much (but I think it's worth it).
They work beautifully in auto, but the SB600 will reach much farther and give you less red eye. Good Luck you have a great camera!
Nov 10, 2009 | Canon PowerShot EOS D60 Digital Camera
Same problem with my SB600
If you are in India, I can help you out in solving it.
+91 9341932677 johnsheen
Jul 02, 2009 | Nikon Speedlight SB-600 TTL Flash
Sb600 display fine, but no longer flashes
Your flash has a bad flash tube . make sure the batteries are in corectly and youhave a ready red light .
Nov 08, 2008 | Nikon Speedlight SB-600 TTL Flash
Auto Flash DOESN'T WORK
if the camera still takes photos with no additional issues, i suggest you buy an external flash like a sb400 or an sb600. getting the flash serviced will fetch you around 100-150 usd which is about the price of the sb600.
Sep 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon SB600.
The flash unit is very compact and the high voltage is at 330volts .
NIKON uses strink warap onn the ends of the tube also and the trigger lead will
pull out of the trigger coil if not careful .
If you need repair contact.
BERRIE SMITH CAMERA REPAIR
bbmw@bellsouth.net
770-312-0719
Jul 15, 2008 | Nikon Speedlight SB-600 TTL Flash
SB600 Works Erratically...
If red light on flash is blinking, flash is charging. In shooting rapidly, sometimes flash will go off even though it isnt fully charged. This can give dark shots. Flash eats batteries like crazy, best to always use fresh batteries for each shoot.
Apr 14, 2008 | Nikon Speedlight SB-600 TTL Flash
Sb600 wireless mode not working...
Remember that even though sb-600 is wireless, it is based on infrared. This usually means having a clear line-of-sight between flash commander and remote flash. Any object that gets in way can block signal from flash commander. Weak batteries in flash will also cause remote operation to be sporadic.
Mar 13, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
473 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
