Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Router was disconnected and I cannot locate the port it must be connected to on my modem.
    Producer:
    Uploaded 30 video answers.
  • 95 Answers
Hi Tawhelan....
Please watch the following 2 videos very carefully......
(I HAVE PROVIDED YOU A FREE OF CHARGE SOLUTION TO YOUR PROBLEM, PLEASE RATE ME ACCORDINGLY)
Good Luck ;-)
Posted on May 11, 2010
How to connect a rca thomson router to wifi
You are trying to connect to a modem, not a router, the router, a wi-fi version, is what you are connecting to your network.
First, power off all equipment, computer and modem, use the network cable you have connected to your computer from this modem and disconnect from the computer, connect it to the differently colored port on one end of the Belkin, the others have numbers, connect a network cable from one of the numbered ports to the computer.
Now power on the RCA modem, wait until lights are steady, then turn on the new Belkin router, wait until lights are active, just a few moments, then power on your computer, you should now have internet access and be able to locate the manual from the Belkin's website to further your setting up a passphrase or setting up some security on your wi-fi.
Jun 14, 2014 | Thomson Rca / Digital Broadband Modem...
How do i connect belkin n300 wireless router to motorola surfboard SB5101 cable modem?
The ISP modem (cable) connects to wireless (yellow port) PC and other devices connect to any port available on wireless. This is the standard setup.
Aug 28, 2012 | Belkin Share N300 Wireless N Router
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
Unable to connect VPN using Arris Modem & Comcast Router
hi, mate check firewall settings of your modem/router. Then contact your IT administrator and he should be able to make changes to configurations for you. In most cases if server classify's your connection as unsafe it rejects it.
Jul 17, 2009 | Computers & Internet
Conect the router?
1. Unplug your DSL modem’s power supply.
the old router and plug it into the gray port on the new router.
port on the Router.
modem to start up.
4. Locate the CD in this guide and insert it into your computer.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
May 17, 2009 | Belkin (F5D72304F5D7000) Router
Media disconnected
If you are using one box (or modem/router) only, when your computer says media disconnected, it means that your computer does not detect your modem.
You can try unplugging and replugging the ethernet at the back of your computer or laptop. make sure that the light on the ethernet port is lit up (especially for desktops, not sure about laptops though).
You can also do the same process with the ethernet cable from your modem/router. if your modem/router has other ethernet ports in it, try to connect it to other ports as well. If your computer still says media disconnected, try purchasing or borrowing a new ethernet cable.
Also make sure that your ethernet adapter is working properly and that media disconnected follows after ethernet adapter local area connection and not wireless connection.
Hope this helps!
May 04, 2009 | D-Link AirPlus DI-524 Wireless Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
How do i connect up my router
To physically install the router
Step 1: Connect the power adapter Connect the power adapter to the router and plug it into an electrical outlet not controlled by a wall switch.
Step 2: Connect the router to the computer Disconnect the ethernet cable that is connecting the broadband modem to the network adapter in the computer. Connect the ethernet adapter in the computer to one of the LAN ports on the router.
Step 3: Connect the router to the modem Connect the ethernet port on your broadband modem to the WAN port on the router.
Step 4: Check link lights and connections
Check the front of the router to make sure the Power, WAN and LAN1 lights are on.
Jun 29, 2008 | Computers & Internet
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing 192.168.0.1 in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see http://www.fixya.com/ThreadView.aspx?thid=102081&prdid=252188 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Feb 19, 2006 | NetGear FR114P Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
