Question about Whirlpool GH7208XR Convection / Microwave Oven
Error code F2.H2 hood keys scanning. This problem
Error code F2.H2 hood keys scanning. This problem is recurring. Previously, I have unplugged the unit for 30 minutes, and the problem goes away.
This time that hasn't worked. What do I do now?
3 Suggested Answers
  • 949 Answers
SOURCE: error message on a whirlpool microwave oven
The F2 H2 error code refers to a faulty hood/light switch. This is a combonation board located just behind the buttons on the left panel. The part number for the switch board is 8206049. Since the screws holding this left panel on are only accessable with the door of the microwave removed, I would recommend this repair to be done by a profressional repair person.
Posted on Apr 18, 2010
Testimonial: "Quick, straight to the point answer - great!"
Ranglo
  • 1194 Answers
SOURCE: A code of F2 appears on the LED clock timer - not
F2 is a bad keyboard error code. Try this, unplug the unit, open the control panel and disconnect the ribbon cable from the control board, plug back in, if f2 comes back on the board needs replacing, if it does not, then the problem is with the keypad.
You can visit this link if you need any help regarding replacement of the touch pad.
Hope this helps. Thanks and have a nice day.
Posted on Jul 05, 2011
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
May 28, 2015 | Microwave Ovens
Whirpool microwave
take its back to show room give its back its was is in warrenty
do noting if its was in wattrety compny is replaced its free of cost
Mar 07, 2008 | Whirlpool MH3184XP Microwave Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Shows SE and not working
The SE error indicates a short in the key panel. You can try resetting the microwave by unplugging it (or turning off the circuit breaker). Leave it off for a minute or so. If the code recurs, check if the microwave is under warranty. If it is still covered by the warranty, contact Samsung for repairs. If it is out of warranty, decide if it is worth sending the microwave in for repairs. (You'll have to pay a fee for diagnosing the problem; that will be applied to the actual repairs if you have the unit fixed.)
I hope this helps.
Sep 06, 2013 | Samsung SMH9151 Microwave Oven
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
A code of F2 appears on the LED clock timer - not always, but peridically every 30 seconds or so. I unplugged the unit, for 30 seconds, plugged it back in and it worked for about 20 seconds. Then the key...
Jul 05, 2011 | Whirlpool MH1150XM Convection/Microwave...
Whirlpool ADG 4956 - problem F2
Hi, here is the answer for f2 "F2 - error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
Apr 24, 2011 | Whirlpool Microwave Ovens
Error message on a whirlpool microwave oven ''F2 H2 Hood Keys scanning''
Apr 18, 2010 | Microwave Ovens
Kitchenaids microwave error message F2.Q1. What to
F2.Q1 Not reading keypad
inputs
1. Unplug microwave oven or disconnect power.
2. Replace the user interface board (UIB).
3. Replace the door control assembly.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
Many of the error codes may be solved by power cycling: unplug microwave oven or
disconnect power. After one minute, plug in microwave oven or reconnect power.
i found this info on a tech sheet hope this helps, let me know how it goes... some of those electronics had 5 year parts warranty i would check that out....Also u might be better of buying a new one if its out of warranrty as some of those boards are expensive, obvioulsy unplug unit first try to reset it self.
Feb 14, 2010 | KitchenAid KHMS2050SSS Microwave Oven
Whirlpool Microvave Vent Model GH7208XRQ
It's better to reply back instead of starting a new thread.
Unplugging it for a while and then plugging it back in is how you reset it.
I put in a message to Whirlpool technical to see if they can tell me what this code is. I'll reply back when I find out.
Mar 19, 2008 | Microwave Ovens
Whirlpool GH7208XR Convection / Microwave Oven Logo
932 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
