My tv is a digistar and there is no code can u help me.
Hi go here for the complete usermanual, and try thid following.
If none of the codes listed under
“Device Codes”on the back of this
guide match your device, you can
search for a set of commands that will
work. Your remote will sample all the
codes in its system for that device
mode to find one that will allow you to
control your device.
1. Press and hold a device mode
key (AUDIO, DVD/VCR, or TV) for
at least six seconds. The LED for
each device key lights up, then
the key for the device you
selected remains on.
2. Press a function key (such as
Power or Mute). The following
function keys are valid for
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
The device key’s LED blinks
three times, then turns off.
3. Press !. The remote will send
the IR command for the function
you pressed in Step 2.
4. If the device performed the
function you pressed, press OK.
The remote will now control the
device you selected in Step 1.
If the device did not perform the
function you pressed, repeat step
3. Press " to retry the previous code
I hope this helps
Please rate accordingly
Thank You
sserpentio
