Question about HP Officejet Pro K850 InkJet Printer
HP Officejet ProK850 will not engage to pick up paper First the yellow cartridge was replaced due to indicator light; then when resetting the gears sounded horrible. After removing the backside unit and placing back into place. The gear problem has resolved itself but it will not pick up the photopaper.
The colours aren't always true to the monitor. How do I fix that?
Posted on Oct 05, 2010
How do I replace the yellow ink cartridge?
Open up the Panel It has the writing HP office jet pro Etc. on it, then the cartridge/head will move toward you, push in on the yellow cartridge until it clicks and release it will disengage and you can remove old cartridge.
Installation is exactly like removal insert new cartridge until it clicks release and it will engage.
Close panel and the cartridge/head will move back to previous position
Jun 02, 2015 | HP Officejet Pro 8600
Rollers not picking up the paper or picking too many pieces at once.
Pickup rollers can be easily replaced if you want to try that first. But the other noises could point to stripped gears or a different problem internally
Jan 08, 2014 | HP Officejet Pro 8500A Wireless All-in-One...
Hp laser jet 1200 printer,orange light stays on and it doesn't pick the papers from the tray paper..problem?
Here is a link to the HP tech support site for that model printer with the error lights and what they indicate and the solution to correct each warning light pattern. I hope this helps.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl10633
BuddyMc
Aug 23, 2012 | HP LaserJet 1200 Printer
Hi i have a hp officejet 4355 all in one printer at my place. i m having problem fixing with the cartridge as it is showing error. pls guide
Problems with Hewlett Packard Officejet 4355 printing can often be due to issues with the cartridges. The printer has two cartridges, one black and white, and one color. Both can be physically inspected for problems. The printer also has a self-test report to determine if there is a non-obvious problem with the cartridge. The report can provide valuable information, including status.
  • 1
    Take the black ink cartridge out of the slot on the right. Be careful not to touch the ink nozzles or the copper contacts.
  • 2
    Look at the cartridge and make sure that the plastic shipping tape isn't still attached. There shouldn't be any tape covering the ink nozzles.
  • 3
    Replace the black cartridge and then perform Steps 1 and 2 on the color cartridge. The color cartridge is the one on the left side.
  • 4
    Print a self-test report. Load paper in the tray and press "Setup." Press "2" and then "4." The HP Officejet 4355 will print a report. Make sure the lines of color extend across the page. Missing, faded or streaky lines can indicate a cartridge failure. If the color bars don't show as black, cyan, magenta and yellow, you should clean the cartridges.
  • 5
    Press "Setup" and then press "6" and then "1." The print cycle will commence. Allow it to complete and then print another test report. If the test still shows errors, replace the cartridges.
  • Feb 01, 2011 | HP Officejet 4355 All-In-One InkJet...
    Hp Besiness inkjet 1100 fault codes cayan maginta ink and paper lights come on dead
    HP Business Inkjet 1100 stops everytime after the first line stars to print. The power is one, the ink drop light is lit, the "yellow" indicator light also on, and the paper light all on. None of them blinking. We replaced the yellow cartridge with a brand new HP 11 yellow cartridge. Turned the printer off and on to reset. Printer comes on everything looks good till you try to print anything, even a on line word doc? Then it happens again, so we replaced the yellow again...same thing. We ever cleaned print heads, Any assistance would be welcomed?
    Jan 12, 2010 | HP Business Inkjet 1100dtn Printer
    Printer does not pick up paper or complains cartridge jam
    Depending on the printer it it could be the transfer rollers that need cleaning or replacing. Due to the paper residue on them. Also this could be worn gears in the printer. Over time the rollers get crystallized or glazed and fail to move the paper forward. Many manufacturer have resolve this issue with using different materials to minimize this but still there is an issue from extended usage. Call the manufacturer or a qualified printer technician to check the printer.
    Aug 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    HP will not recognise new cartridge
    The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
    May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
    Printing
    The printer hp officejet v40xi is asking for a cartridge alignment. When I press enter the printer does nothing want take paper or engage the paper nothing
    Aug 12, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
    HP Officejet Pro K850 InkJet Printer Logo
    137 people viewed this question
    Seeker5211
    Seeker5211
