Back to:
Tags:
Vacuums
Generic problem for all Vacuums
This is a EURO-PRO X
posted by buyerprint on Mar 28, 2008
This is a EURO-PRO X Shark Steamer Model S3325, there doesn't seem to be any power in plugged in, no lights on the handle. Bad switch or is there a fuse?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 30, 2008
Not Rated (0)
domvac
Rank:Guru Guru
Rating: 88%, 155 votes
There is usually a heat sensitive fuse link installed in the handle and is incorporated in the cord connection. If the machine gets too hot or is run while dry, the fuse can blow. You would have to replace the fuse, as they are not resetable.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on This is a EURO-PRO X:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac deluxe spinscub model # F5866-900 how do i...
Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson is clogged right on top of the cyclones, how on...
Vacuums
Need remote code for a one for all remote
Vacuums
when i plug in my electrolux model 130A central vac hose...
Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark steam mop main light dose not come on when pluged...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
