Question about Kenmore Refrigerators
Refrigerator side of side by side, the door will not open, no visible damage to outside of refrigerator, this is an older model refrigerator Model 52212100
  • Kenmore Master
  • 3,361 Answers
There is most likely a inside shelf out of position and holding the door closed.
Remove the hinge screws from the top corner and lift the door off the bottom hinge to open it.
Check all shelves before re-attaching the door.
Posted on May 11, 2010
How do I turn demo mode off on FGHS2631SS Frigidaire?
Are you sure you have the right model #? Your refrigerator's model number may vary by type. The model number of a top freezer refrigerator can be seen along the upper left side wall of the fresh food compartment and is visible when the door is opened. The model number of a french door and side-by-side refrigerator can be seen along the upper right side of the fresh food compartment and is visible when the door is opened. model-number-refrigerators.png
Sep 10, 2014 | Refrigerators
Tip
Finding Your Model number on Older GE Refrigerator (Frige)
Finding Your Model number on Older GE Refrigerator <br /> <br /> If it is a side by side look in the frige side on the side walls near the bottom. <br /> <br /> Also check the bottom right side of the frige between the door and the base.
on Mar 23, 2011 | Refrigerators
We cannot change the temperature of the freezer. Everything,even the water to the ice machine is so frozen (8*) that we cannot get ice. How do we change the temperature
I am not sure what model you have, but on my RF265AABP there are two buttons and digital displays at the top of the refrigerator, visible when the doors are open. One sets freezer temperature, the other refrigerator temperature. On my model if they read 88 88 with a blinking digit, it indicates a broken wire to a temperature sensor, usually the ice maker sensor since it tends to get snagged and damaged easily.
Apr 04, 2013 | Samsung 24.8 Cu. Ft. Side-by-Side...
Ice dispenser door open. Ice freezes at bottom of bin, rendering the dispenser useless
If the ice door is open that will need to be repaired first before solving the ice melting and stopping the ice auger from moving. What may be happing is the ice door stuck open causing warm moist air from outside the refrigerator to be drawn in covering everything with frost and possibly locking down auger and causing the refrigerator to run continuous. What is the model number found around the fresh food section? Thanks Sea Breeze
Nov 16, 2012 | KitchenAid Architect Series II KSSO42QTX...
Re: GE Model TFX24R Side-by-Side 23.6 Cu Ft Refrigerator The refrigerator door needs to be raised to correct closure, it is visibly low and stands open. However, I have not been able to figure out how...
the cam must have broke and this is why the door fell,the cams are made of plastic,part number WR2X4901 and it's around 15 dollars,there's a couple of shims that are there too but they should still be good,
May 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
How do i gain access to the defrost timer in a kenmore side by side refrigerator model 106 9532?
what's the rest of the model number?open the fridge door,look up near the cieling on the right hand side and send the whole model number,if it's an older machine the model number could be down near the bottom hindge on the fridge door.send that and i can help you.some are behind the bottom kickplate and some are in the fridge side depending on the model.
Mar 03, 2011 | Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
We have an Amana side by side. The freezer door
hi. First of all, finding the model number can be a bit of a challenge. here are the places to look:
  • Inside the refrigerator or freezer, on the upper left or right side wall
  • Behind the lower crisper drawer
  • Behind the lower toe kick-plate
  • On the face frame of the refrigerator body
  • Nov 17, 2009 | Refrigerators
    Refrigerator Door Does not Close Properly
    Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
    May 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
    Can't find the filter in frigidaire elite older model side by side
    that model has a pure source 1 filter. it is located in the top right corner in the rear of the refrigerator compartment. open ur frige door and youll see it. it has a plastic cover that you twist off. then pull down on the filter, put in the new one, and twist cover back on
    Mar 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
    Refrigerators Logo
    62 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    oldblindman
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
