Question about Sony Handycam DCR-HC36 Mini DV Digital Camcorder
Sony video 8 handycam ccd-tr410e
Camera would not work.it rattled when moved.i removed the cover from the tape slot, and a spindle fell out.it measured about 1/4 inch long by
3/16th diameter with a rubber outer and a brass inner.when i replaced it
the camera worked perfectly.the problem is how do get it to stay in?
regards; boris yadek.
SOURCE: How do I hook up a Sony Handycam Video 8 CCD-TRV41 NTSC to view on television?
I still have my CCD-TRV41 and the manual intack. You will just need a audio/video cable (2-colored or 3-colored) to view your movies.
Posted on Sep 09, 2008
  • 3 Answers
SOURCE: drivers for ccd-trv608 HI-8
This is the only solution that I have found that really works. The only problem is you need access to a computer running XP. On the Sony website they have drivers for XP. The XP drivers work for Vista, but vista will not let you install them normally. So on an XP computer goto the sony website and download the xp drivers and install them on the xp computer. Then all you need to do is go into your C: drive and there will be a folder called "Drivers" in that folder you will see the sony usb folder. Just copy it, onto a disc or thumb drive. then copy the folder to your vista computer. You can put it anywhere, I jsut put it on the desktop for easy access. Then plug in your usb cable for the camcorder, let it try to install, then it will give you an option to sellect the files yourself, browse to the folder you coppied onto your desktop and Viola, Vista will find the drivers and install them. you now can use the usb connection on your camcorder.
if you are having a hard time finding the files, email me and I will send them to you.
austinpack@gmail.com
Posted on Jan 06, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony CCD-TRV608 The pinch roller
Below is an exploded view of camcorder mechanism and Pinch Roller is marked with red line. Hope this will help you to install it again.
Posted on Jan 26, 2009
leecom72
  • 4806 Answers
SOURCE: sony handycam ccd-trv35e how to video record on my laptop
Hi there.
The computer must have standard Audio/Video (A/V) RCA input jacks and compatible video capture software to complete this procedure. Because there are many different video capture applications on the market and we cannot reasonably know which video capture software you are using, Sony is unable to provide specific instructions or support for software we do not manufacture. However, many video capture applications have detailed help files, including specific instructions about capturing and importing video from a camcorder to a computer.
The help files should be available in the Help menu of the video capture software or in a separate file on the software disc. If you cannot find instructions in the help file or on the disc included with your software, consult the software manufacturer for more detailed support information.
  1. Connect an A/V cable to the A/V output jack of the camcorder:
    If your camcorder has standard A/V RCA output jacks, use standard A/V cables for the connection. avstnd.png
    If your camcorder has a mini A/V output jack, use an A/V cable with a mini connection on one end.
  2. Connect the other end of the A/V cable to the A/V input jack on the computer.
  3. Turn on the camcorder to the VCR, VTR or PLAYBACK mode.
  4. Cue the video in the camcorder to the beginning of the video footage to be transferred.
  5. Turn on the computer.
  6. Start the video capture software.
  7. Begin playing the video in the camcorder.
  8. Begin importing the video with the video capture software.
Good luck and thanks for choosing FixYa!!
Posted on Jun 02, 2009
SOURCE: handycam won't play tape
i have thi problem to it is the x700 sony one :/
let me know if you have sorted the problem and tell me the soluvtion as i haven't yet :/
thankyou
Posted on Feb 24, 2010
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
Sony video handycam ccd fx420
The take up spool is no longer working. Time for a new V8 machine.
Jun 10, 2017 | Video Cameras
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
The Eject button on my Sony Handycam CCD-TR818 Hi-8 Analog Camcorder does not work. A tape is in there ( I can still record and view the tape fine) but I can't take it out and put a new one. Any...
This cannot be done by you and you need to refer this to a trained camera technician.
Any force applied to remove the cassette will damage the mechanism.
Jan 14, 2011 | Sony Handycam CCD-TR818 Camcorder
Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
May 18, 2010 | Sony Handycam CCD-TR618E Camcorder
Sony 8 MM HaNDYCAM PROBLEM
Yes It Is Possible.
1. Cable options you can use S-video or RCA.
2. VHS payer that has a recording option. Make sure that it supports the Sony Handycam 8mm.
3. The procedure on how to transfer the 8mm to VHS is the same as how you view your video on the TV.
4. S-video or RCA should be connected on the Handycam and the other end is on the TV.
5. You can follow the instruction on page 27 (Sony Handycam CCD-TRV37)
6. You can also follow page 52 (Sony Handycam CCD-TRV37 )
Go to this Link for the user manual and the full instraction on how to connect the cables.
http://www.derrybryson.com/manuals/Sony/Analog%20-%208mm%20&%20Hi8%20Camcorders/CCD-TRV57.pdf
Apr 03, 2010 | Sony Handycam CCD-TRV37 Camcorder
Sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
Try to clean video head with cleaning cassette, if same position than video head need to be change
Mar 28, 2010 | Sony Handycam CCD-TRV43 Camcorder
Moisture symbol on very old sony cam
I have a CCD-F385E with the same problem i kept putting the tape in and out and it started working.
Nov 25, 2009 | Sony Handycam CCD-TRV81 Camcorder
My sony handycam was stolen how do i play back my 8mm tapes is there an adaptor available?
No adaptor for 8mm tapes. You need to have Sony camcorder or video-8 player for playback these tapes.
Feb 21, 2009 | Sony Handycam CCD-TRV87 Camcorder
Sony Handycam DCR-HC36 Mini DV Digital Camcorder Logo
175 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
