Question about Kenmore 95420 / 95421 / 95422 / 95424 / 95429 Electric Kitchen Range
One of my burners will not turn off, I have to unplug it from the wall the rest of the burners work fine but the front right burner is on high no matter what the dial says
  • Kenmore Master
  • 3,361 Answers
The switch is welded closed.
It must be replaced.
Posted on May 11, 2010
Gallery series convection oven delivered new yesterday.First burner that was turned on(front,right side) doesn't work. The rest do.
Hello Karen, thank you for your post!
Since you just received your unit recently, let's try resetting the range. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the range on. If resetting the power does not correct the issue, your appliance could possibly have a faulty burner or a potential wiring failure to the burner. At this point, I would highly recommend contacting or visiting the manufacturer website to find a service provide near you and to verify warranty information. If there is anything else that I can help you with, please feel free to reconnect!
Best of luck!
Sep 19, 2013 | Frigidaire Gallery 30" Self-Cleaning...
My right front burner wont turn off. My dad checked the control knob and it seems to be working. He unplugged it from the front burner and put it on the back to see if it did the same thing and it did. ...
with a model number to know exactly how power is supplied to the surface burners its going to be hard to let ya know anything definate...but do ya have knobs that ya turn to turn on the surface burners? if yes knobs..their will be terminals on the switch marked L1/L2 on those 240vac should be there all the time when turning the knob onto high on terminals marked H1&H2 should be 240vac to the burner
if it has the touch button to turn on the surface burners 240 vac into board all the time ..4 individual outbound power places (one for each burner) and the one for that burner also should have 240 vac when set to high
in either case if 240 vac out to burner the burner is bad
if 240vac into switch/board and not out..switch/board bad
Aug 26, 2011 | Kenmore 99123 Electric Kitchen Range
My whirlpool range ss630per-1 burners will ignite except of front right which give no ignitor sound at all, but the Rear Right works fine. any solutions?
Each burner control knob has a built-in switch that controls the igniter. It appears the front right burner switch in the knob is possibly defective. They are replaceable but it requires dis-assembly of the range front. Are all the igniters in a sequence? Have you tried turning the front right burner on while another burner has the igniter on. This may let you ignite the burner automatically. When you have another burner igniter clicking try turning on that burner. If the range has rectification igniters that will not work.
Sep 26, 2009 | Kitchen Ranges
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
All ignitors work, but right front burner will not light.
gud day,remove the burner base & plate to see the injector (gold color) remove it by using soccet wrench diff.size for diif.brand (common is 7mm) remove it carefuly then u see the small hole very small,clan the hole by using niddle or anyting u want to clean,b4 u back the injector, clean the place wer the injector position by using a vaccium.clean it all if u want but carefuly.unplug & turn of the gas. tnx gerbee gomez
Jan 26, 2009 | Jenn-Air JGD8345 Gas Cooktop
Front left burner wont work.
It sounds like the left front control or element has a high resistance short.
Jan 23, 2009 | Tappan TEF242 Electric Kitchen Range
GE Spectra JBP64BB front right large burner won't work anymore
how are you the GE Spectra JBP78 Electric... Problem: Subject: the proble is that i had a shortge of power and i have the ""lockdoor"" showing
Jul 29, 2008 | GE Spectra JBP78 Electric Kitchen Range
Burner adjustment
After discussing the problem with your advisor it was determined to be a faulty infinite burner control switch. I purchached a replacement and the stove works fine.This service was very halpful to me.
Jul 21, 2008 | Jenn-Air Kitchen Ranges
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Kenmore 95420 / 95421 / 95422 / 95424 / 95429 Electric Kitchen Range Logo
83 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
