Question about Dell E173FP 17" LCD Monitor
I don't know how to take apart the stand off my monitor
  • 11,361 Answers
Look at the video here: http://www.lcdrepair.us/E172fpbvideo.html
You can also buy the replacement board from them.
http://s807.photobucket.com/home/budm/allalbums
Posted on May 12, 2010
Testimonial: "Thank you so much! :)"
Can't get it to stand up right, my screen keeps falling down and won't stay up
look for the adjustment screw at the base go from there
and download teh manual
Sep 14, 2014 | HP 1730 LCD Monitor
My stand will not go back so I can attach the base...please assist
Hello and welcome to fixya.
I believe you are trying to assemble the monitor and you don't have the manual in hand so here are two links that might help you out:
1. The hp w1907 user manual - see page 13 for assemble instructions or page 22 (if you are looking to only adjust the monitor height).
2. An eHow.com brief explanation.
If you are looking for disassembling the monitor itself to repair it, please let me know so I can re-post another solution although there are a couple of youtube videos already online to show complete repair instructions for the specific monitor.
Let me know if this helped you at all for this.
**Don't forget to rate this solution**
Thanks.
Regards from FixYa.com
Apr 16, 2011 | HP w1907 LCD Monitor
In moving to a new apartment I flattened the neck of the circular stand with the monitor LG flatiron slim 19" into the box. Went very easily. Now when I put up my computer the stand of the monitor...
On my HP monitor on the stand, I have a locking mechanism that doesn't allow the display to be raised. I need to press a button on the stand while pushing down the display, then the button is possible to be pressed down. then while holding it down, I can pull the display upwards as much as it comes.
the stand locks in my case when pushed all the way in.
Maybe this is the same thing on yours? Maybe not?
Oct 03, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
How do I take apart Acer AL1715 LCD Monitor
You do have to remove stand (the stand hinges are covered by the plastic pieces that you just pop them out) and all the screws. Start at the bottom to crack open the case. See AL1716 (almost the same as 1715):
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1716/
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 27, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
How to open dell monitor cover model E207WFPc
Remove the Stand, Remove the 4 Screws from behind the spot where the stand connects to, then take a flat ended object such as a butter knife or a sharp knife, and unclip the black face. then the screen comes right apart, this solution is also the same for the 20xx-30xx Dell WFP Models.
Apr 14, 2010 | Dell E207WFP LCD Monitor
I cant get the stand for the monitor to go back
I had same problem, the stand wouldnt move.I had to take it apart and loosen the nuts for the hindge. HP torgued the nuts to tight on the hindge. it works fine now.
Dec 12, 2008 | HP w1907 LCD Monitor
Monitor stand and power cable needed
Hi Kiran,
If the power cable matches the power cable of your computer, it's a standard 3 prong power cable and you don't need a specific kind. If it's a small circular type you will need an external AC adapter, the type will depend on the manufacturer and make of your monitor. These can be found on eBay usually. Most monitors use different types of stands, but if your monitor has the standard VESA 75 or 100mm mounting holes on the back, you can find many monitor stands that are compatible with it. The standard VESA mounting holes are usually used for wall mounts but lots of stands connect to the monitor this way. You can tell by a set of 4 holes for screws or bolts on the back that are either 75mm or 100mm apart (vertically and horizontally). Don't forget to get the right kind of bolts for the stand, if it doesn't include them.
Jun 10, 2008 | AOC Computers & Internet
E173FP monitor - blank with blinking power LED
Remove the stand by removing the screws at the center back.
pry the front and back plastic apart with a large flat blade screwdriver. The front and back snap together so you need to "pop" them apart.
Mike
Apr 13, 2008 | Dell E173FPb 17" TFT LCD Monitor
How to open casing
Just managed to open a FP17G+ monitor. My hope is that FP17G is similar and that this comes in handy.
There are 5 screws holding the casing together. Four are in the corners (black screws on my monitor). The 5th is right under the monitor stand (silver screw on my monitor.
To open the monitor, I had to:
1) Remove the monitor stand. To do so, you need to take out the two screws at the point where the base connects to the monitor (right above the pivot point) and slide out the monitor stand. THis should give you enough space to take out the 5th screw.
2) Unscrew the five remaining screws on the back of the monitor.
3) At the bottom edge of the monitor, there are two gaps between the front and back plastic panels of the monitor. You can place a wide screwdriver in this gap and gently pry apart the front and back of the monitor. Continue around the edge and the monitor will be open.
Best of luck... If you figure out what is wrong inside, let us know (I am trying to fix the same problem).
Apr 05, 2008 | BenQ FP71G 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
196 people viewed this question
Alun Cox
