Question about Pioneer PRO-119 60" Rear Projection Television
I have a older model
I have an older model PioneerProjection Monitor Receiver (model Pro-119). I have been experiencing color convergence problems that until recently was able to solve by using the owners manual's adjusting guide. The red, green, and blue crosses are so far off that the remote control is unable to line them back-up completely. Any suggestions?
  • presson942 Mar 29, 2008
    I would definitely like the link where I can order the ICs. Thanks alot!
  • Pioneer Master
  • 8,617 Answers
You will need to replace both convergence ICs. This is a simple common repair for all projection TVs. If you would like I can post a link where you can order your ICs and they provide step by step instructions on how to remove the old and install the new ones.
Posted on Mar 29, 2008
  • Sonny Berry
    Sonny Berry Mar 29, 2008
    Here is the link. I am one of their support techs. They will include free installation instructions with the ICs. If youre not sure which stk numbers your ICs are post an email as I handle all tv questions and I will email you with the correct ones to order.
    http://servicemanuals.vstore.ca/
2 Suggested Answers
SOURCE: I have an older model
If you have a cable box, unplug the tv and cable box from wall for 1 minutes, then plug both back in. This should solve your problem. It worked for mine.
Posted on Jul 26, 2008
Sat finder detects signal on 61.5 Sat but receiver does not display or lock.
Hi, Mary with Dish Network Customer Service. The 61.5 Satellite carries mostly High Definition programming. If your Satellite Dish is an older model, it is not equipped to bring that Satellite in. It is the part on the Dish called the LNBF (the eyes) that will pick up the satellites. Your receiver is a Standard Definition, you should be reading the 119 & 100 Satellites. I hope this helped but if you have additional questions, please let me know.
Dec 22, 2010 | DISH Network 311 DTV Receiver
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Red shadow?
call a tech and have them converge the tv.its either that or the focus
Jan 02, 2009 | Pioneer PRO-119 60" Rear Projection...
Blue shadow above writing and pictures on screen
it sounds to me like your convergence boarde is bad and needs replaced
Oct 23, 2008 | Televison & Video
I'm experiencing different colors on the tv when displaying an image.
If these colors appear to be like a 3-D image, the problem is in the convergence circuit. Please update this with the make and model and I will provide you with further information and instructions.
Thanks,
Dan
Sep 24, 2008 | Televison & Video
Dish Network - Dish 500 Satellite 110 is not being recognized
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Sep 04, 2008 | DISH Network 301 DTV Receiver
I have an older model PioneerProjection Monitor Receiver (model Pro-119). I have been experiencing color convergence problems that until recently was able to solve by using the owners manual's adjusting...
Mar 28, 2008 | Televison & Video
Pioneer Pro-119 Rear Projection TV
HEY DF-YOU SET HAS 2 BAD STK392-110 CONVERGENCE ICS.THEY WILL NEED TO BE REPLACED AND IF NO OTHER CONVERGENCE CIRCUIT PARTS HAVE FAILED YOU SHOULD BE ABLE TO SET YOUR CONVERGENCE ALIGNMENT PROPERELY.TV REPAIR ESTIMATE SHOULD BE ABOUT 300.00$.DO IT YOURSELF FOR ABOUT 40.00$.
Nov 24, 2007 | Pioneer PRO-200 60" Rear Projection...
Convergence problem, lower left corner fixed green gun convergence bows upward
You have a componet out of tolerance in the green drive circuits, resistor or capacitor. If you have the service manual you should be able to take some raedings off the test points for the circuit and be able to track it down. I am enclosing a link where you can purchase the service manual for that set for 10.99. They will mail it to you unless you go back to the site and request that they email it to you by clicking on the contact us link. They also offer unlimited free support if you purchase your manual. I am one of their support techs. Hope this helps. Heres the link
Dec 27, 2006 | Pioneer PRO-119 60" Rear Projection...
Televison & Video Logo
122 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
