Question about Brother MFC-7220 All-In-One Laser Printer
What is back door in this printer - Brother MFC-7220 All-In-One Laser Printer
  • 240 Answers
The back door is the cover on the back of the machine. If it says back door open, you may have a paper jam.
Open the front cover and take out the drum and toner. If you see a page you need to take it out.
Thanks,
Pat
Posted on May 12, 2010
How do you remove paper stuck in the back of a P3015 printer?
If the paper is jammed in the fuser, sometimes the only safe way is to remove the back door to gain better access. Open the back door, on the right side you will see a white arm that attaches to the door and disappears into the printer. Pop it off the shaft if is clicked to. Then remove two screws from the back door. Lift the lower panel that covers the paper drawer and pry on each side of the lower back door. Once those catches release, pull the back door off by pulling the bottom of the panel towards you and the top will pop out. When reinstalling the door, make sure to reattach the white arm to the door before closing the door. Failure to do that can result in that arm getting broken,.
Oct 13, 2016 | HP P3015 Laser Printer
How do I close the door to my printer? It seems that one of the hinges is broken apart.
If it's broken, you can't get it back together and your prrinter won't work with "door" opem look for the sensor which indicates that door is open, stick it somehow so it should show door closed and used happily forever your printer. If this trick is not possible, no way, take your printer to an HP repair center and get installed a new door.
Aug 27, 2015 | HP Officejet 6310 All-In-One InkJet...
Paper is jammed in the back-- can't figure out how to get it out.
Hi
Please turn off the printer and unplug it from main power. To remove any stuck paper, you'll need to open the rear door of the printer. The back part/door can be removed. After removing this door, check for any jammed paper. Close the back door and open the front door of the printer (from where you can see and change the cartridges). Now check for any paper jammed near or under the carriage. Remove any paper jam if any. Check for small bits of paper as well.
Now turn on your printer and check.
Daniel Scott
Jun 17, 2010 | Canon MP560 All-In-One InkJet Printer
Rear door won't go back on
Take the printer to a qualified technician, and pay them $25 to reconnect the door.
Jun 01, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
ERROR:0Xc0620004 HP 1610
Well you can please follow the below steps -
1. Power off the printer by removing the main power plug.
2. At the back of the printer if it is a HP printer, there is usually a little back door (latched on both sides). Open that door and you will be able to get the rest of the paper out.
3. If you have a duplexer, then that back door wont be there. You will need to remove the duplexer - just press the unlatch button and take off the duplexer. Again, clear the paper out.
4. Put back either the back door or the duplexer securely - until you hear the click sound.
5. Plug your printer back on and switch it on.
Please post comments for more help or information.......
Good Luck!!
Thanks
Mar 20, 2010 | HP PSC 1610v All-in-One Printer
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
How to close the large back panel door? The door will not close and latch into place.
Disconnect the power and ethernet cable, open the lower paper tray slightly, turn your printer around where you have easy access to the back of the printer. Close the main door until it has full resistance. ( The lower right hand corner of the door will be bowed out. ) With the heel the the palm of your hand, "pop" the lower right hand corner of the door, swiftly. Turn printer around, push tray in, reconnect cables, and turn on printer with power switch.
Jun 16, 2009 | Dell 3100cn Laser Printer
Can't get the back door open to remove jammed paper. How do the levers work?
I downloaded the user guide and saw a picture illustration that showed how to open the back door of the printer.  I was then able to follow the visual directions on the printer LED to remedy the paper jam.
May 28, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP6310
Something is holding the top cover on the printer open enough so it is not pressing the switch to tell it it is closed, OR there may be a back door on the printer that is not fully closed. Many printers have an access door in the back for clearing paper jams. If the back door is not fully seated and latched it will cause an error.
Mar 18, 2008 | HP Officejet 6310 All-In-One InkJet...
Back door closed
I did not get any error message but the 6940 printer would not print. Instead "Ready" the printer said "door open". When I deleted printer and plugged the usb cable back in the XP machine found the new hardware, said "Ready" and could print.
Dec 22, 2007 | HP Deskjet 6940 InkJet Printer
Brother MFC-7220 All-In-One Laser Printer Logo
49 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
