Question about RoadPro RPPI-2500W Inverter
Just a question
Do the cooling fans go on once the inverter is turned on,or when it is in use. Thank You
    Guru:
  • 290 Answers
When your inverter is running, the fan will be on, so that the system does the not over heat. This is the same when the inverter it on
Posted on May 14, 2010
I recently purchased a schumacher 410w inverter, while it came on right away and powered my electrical device the cooling fan never came on. Is the fan supposed to run all the time, once its connected.
I recently purchased a Schumaker 410/820 watt inverter. I immediately hooked it up to a brand new deep cell batery I had purchased just prior to receiving this inverter.
I plugged in several devices to make sure the inverter worked and to get some idea of what devices I can expect this unit to handle.
I noticed that the fan only ran when I plugged in a device that drew a certain amount of power from the unit. I also plugged in a CPAP unit to make sure the inverter would operate the unit properly, and noticed that the CPAP only drew 38 to 40 watts of power and the cooling fan on the converter never came on. When I plugged in an oscillating fan it drew around 128 watts from the converter and the cooling fan immediately came on when I turned the fan on. Based on that, I would assume that the cooling fan in the converter only runs when there is enough power being drawn through the inverter to cause the inverter to heat up enough to cause possible damage to or failure of the inverter. I haven't taken the time to find out the power draw at which the cooling fan will run. Hope this helps.
Jul 10, 2011 | Schumacher 410 Watt Power Inverter...
Code P0A93 for toyota PRIUS WHAT IS THE PROBLEM ? Check Engine light and ! and VSC Warning lights I looked up code P0A93 equals StandaRD DTC'S (ISO 15031-6/SAE J2012) WHAT THIS MEAN?
P0A93 is an inverter cooling problem. The inverter is cooled by a dedicated cooling system, which consists of an electric water pump, cooling fan, and radiator. This cooling system is independent of the engine cooling system.The mechanic should check if there is sufficient amount of coolant for the inverter, check if the coolant hose is not bent or clogged, if the water pump / cooling fan motor connections are ok, and of course if both of the cooling fan motors are OK
Sep 20, 2010 | 2004 Toyota Prius
The fans no longer turn on and the inverter shuts
YOu can replace the small fans and it will work fine. Go to newark,com and they have very small cooling fans like that.Same ones that computers have for cooling. You will have to open things up and get some numbers and dimensions.
Sep 25, 2009 | RoadPro Electronics - Others
Radiator fan runs after car is turned off. Only occurs when A/C is run for more than 10-15 min. Shuts off after a few minutes, but is concerning.
That is nothing to worry about the fan remains running after the vehicle shuts off in order for the engine to cool down. Once the motor cools down sensors trigger the fan to shut it off.
Sep 10, 2009 | 2004 Ford Focus
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
When should the radiator fans be running? They only seem to run when I put the A/C on. Should they run at other times? I have a Nissan Sentra 2002 GXE.
One fan should be on once the coolant temp hits a preset number, I believe it may be 205 for teh Sentra. The second fan kicks in once the AC is on.
Jun 14, 2009 | 2002 Nissan Sentra
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
The fan on my 1200 watt inverter does not start when turned on.
No. the fan is to remove heat(obviously) If there is a small or no load on the inverter the fan wont come on(no heat to get rid of)..........this is so a lightly loaded inverter wont kill your batteries as fast.If you load it up(power something big or power several things at once) the fan should start after a few minutes
hope this helps.Good Luck!
Dec 13, 2008 | Whistler PI-1200W 1200-Watt Power Inverter...
2004 Prius Check Engine Light - code POA93
P0A93 is an inverter cooling problem. The inverter is cooled by a dedicated cooling system, which consists of an electric water pump, cooling fan, and radiator. This cooling system is independent of the engine cooling system.The mechanic should check if there is sufficient amount of coolant for the inverter, check if the coolant hose is not bent or clogged, if the water pump / cooling fan motor connections are ok, and of course if both of the cooling fan motors are OK.
P3108 is generally loosing communication with the A/C system control module. This can usually be solved by checking the wires and or the converter inverter assembly.
Jun 17, 2008 | 2004 Toyota Prius
RoadPro RPPI-2500W Inverter Logo
159 people viewed this question
Top RoadPro Electronics - Others Experts
Craig Butler
Craig Butler
jdthefixer
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
