Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door opener motor runs but the chain does not move and the door does not lift. What could the problem be?
    President:
  • 3,197 Answers
Remove the cover from the motor unit and I am sure you will find the drive gear is stripped. You will also find what looks like white sawdust. The part number for the gear is 41A2817 and is available at any good door opener service company. It will come with instructions.
Posted on May 11, 2010
Garage door moves few inches and stops, springs are fine, sensros are fine.
If it is not blinking when it stops, then the capacitor is blown. Replace the capacitor and it should resolve the problem.
Aug 09, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
My Lift Master garage door will not close. It makes the closing noise but the door does not slide down. Whcan I talk to to fix this?
Sounds like you have a chain drive garage door opener and you hear a humming sound when you push the wall console. The motor is running but the chain does not move. You need to replace the gear & sprocket assembly.
Jul 06, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
My stanley garage door opener motor runs but it won't open or close my door
If the motor runs and the chain does not then you have stripped the gears and will need to replace them. If the motor runs, the chain moves but the door does not move then the trolley is not attached or needs to be replaced. Thanks BB
Jul 27, 2010 | Digi-Code Digi Code 5202 Garage Door...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door chain isnt engaged. motor is running
SOUNDS LIKE A BAD GEAR KIT
IF THE CHAIN MOVES BUT THE DOOR DOESN'T IT WOULD BE THE TROLLEY RELEASE. IF THE CHAIN DOESN'T MOVE IT WOULD BE THE GEAR KIT.
HOPE THIS HELPS
Jan 03, 2010 | liftmaster Chamberlain Garage Door Opener...
Lift-master chain drive garage door stuck at the protection bolt
you will have to find were the chain is binding look around the drive sprocket and check the chain to see if it is tight at the bottom or top this will tell you were to start looking for the problem.
Sep 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door model PD200
Take the back cover off and see if the Gear that turns the shaft that operates the chain to lift or close is in good condition.
The gear is probably plastic and 3" or 4" in diameter.
UNPLUG THE OPENER AND DISCONNECT THE POWER BEFORE DOING THE ABOVE.SAFETY IS ALWAYS FIRST.
Jan 16, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
160 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
