Electric windows on 1998 xj8 sport
Drivers window wont go up or down can hear clicking when press button down. also wont open windows now when i turn the key to the left
  • ebonycouncil Apr 24, 2009
    1995 isuzu trooper, someone tried to break into my truck through the driver side window, now my windows wont go up and down. and i thought it was the motor, any suggestions?
  • 26 Answers
1)can you check the holder of louver ,may be its loose or out of the holder .
2)Check the synchronous motor of louver or windows,may be stuck-up or loose.
Thnx
Edgz
Posted on Apr 01, 2008
SOURCE:
1998 expedition driver window fuse or relay
If you hear the relay, you need to pull the door panel and check power at the motor. Power there replace it. No power, the wires tend to break in the rubber boot at the front of the door jam.
Sep 18, 2016 | 1998 Ford Expedition
Window wont go down
I'm assuming your pressing the button
for the window. If this is the case it can me the sw
or the motor
Jul 09, 2014 | Chrysler 300 Cars & Trucks
How to program key fob to close and open windows?
2001 XJ 1. Open drivers door
2. Hold the highbeam selector arm towards you
3. Insert ignition key and key to first position (acc)
4. Release the high beam selector and then pull and release the high bean
selector 4 times.after the 4th time you will hear a chime.
5. Then press the lock button on each remote to program it in.
Jun 15, 2012 | 2001 Jaguar XJ8
Window chevrolet 1998 malibu issues
You will need to remove the inner door panel
Remove the entire Window Regulator Assy,
& switch the motor to a New Window Regulator
Yours Broke,& no, there is no such thing as putting
it back on track
If that isn't the case when you get inside the door,
then the switch broke & only works in the down position
Jun 05, 2012 | 1998 Chevrolet Malibu
The drivers side window will not roll back up. When I push the button to roll the window down, i can hear clicking, but when i push to roll the window up it doesnt do anything and the passenger window...
If you are hearing clicking but there isn't any movement, it is most likely a worn track that will have to be replaced. Good luck and stay cool
Jul 06, 2011 | 1998 Mercury Sable
My 1998 ford f150 4x4 has electrial problems. The dome light, power windows, wipers,electric door locks are not working. Any ideas
Hi, this might be caused by a blown fuse. Check all fuses as there are some systems integrated with others running from the same fuse. If all the fuses are fine you will need to look at the earth connections and power supplies to the systems.
Nov 20, 2009 | 1998 Ford F150 Regular Cab
2001 XJ8 keyless remote programming
This is the procedure from the service manaul:
JAGUAR
XJ8 Remote Control Programming
1. Unlock the Boot/trunk with key.
2. Turn Ignition on.
3. Warning light on dash comes on.
4. When they go out, lift arm rest, inside their is a valley button, Press 5 times within 5 secs of lights on dash going out, Horn & Lights Flash.
5. Press any button on remote, remote programmed.
Jan 16, 2009 | 2006 Jaguar XJ8
Rear window, door wont open from inside
i dont know if ur door is electric or manual.as for the door not opening from the inside it could be a rod has come off from the inside of the door to the handle you have to take inside door panel off and have a look.
Dec 26, 2008 | 2007 Jeep Liberty Sport
1994 Jeep Cherokee Power Window Problem
When you open the drivers door you can see a wiring harness between the door and the body of the car.
You more than likely have wires broken in there.
Jul 19, 2008 | 1998 Jeep Cherokee
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
