Question about Dell Inspiron 1501 Notebook
Battery problem system unable to recognize battery message with boot up
  • 3,940 Answers
Try a new or a known good battery, if that doesn't resolve, then a Motherboard replacement is required
Posted on May 11, 2010
No Boot Disk/Hard Drive Not Found
The battery could be. However, the error seems to point to a bad hard drive, and the hard drive will need to be replaced.
If you do not have a backup of important files, I recommend that you go to a local PC repair shop to attempt recovery.
Aug 05, 2013 | Compaq Computers & Internet
What happened?
the battery gone out of order, needs replacement
Jan 22, 2013 | Computers & Internet
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Unable to reboot "error loading operating system" message
unable to boot. it means you have corrupted boot file.
to correct this problem.
Try to repair OS by using windows installer or reformat dard disk.
Hope i will help you to solve the problem..
May 18, 2009 | Acer Computers & Internet
Non system message
Your boot sequence is probably not set to boot from the Hard drive first. Remove any floppy disks/CD's from their drives and try to boot it.
If you are still getting the message then you have files that are corrupt on your hard drive.
Jan 26, 2009 | Gateway Media Center 610XL PC Desktop
Dell D610 will not recognize password when logging on to windows
some notebooks have a small battery on the mother board remove your notebook battery then remove the small on the motherboard live for a day our 2 then reinstall the battery this should solve the problem
Sep 10, 2008 | Dell Latitude D600 Notebook
Can't start my computer
does the monitor is getting on....do you see anything in the monitor?
Mar 05, 2008 | Computers & Internet
I think my compaq presario desktop has crashed
the computer is not recognizing the contents of your hard drive. you'll need a floppy with command.com, iosys.com and sysinfo.com on it. when inserted into the drive cmos looks here first. if you can access the cmos, check the search parameters to see what the computer boot up sequence is. you may want to change it to recognize the cdrom first, then the hard drive, then the A drive. I had a compaq armada that gave me the same message but I was able to reformat the drive off DOS 6.2 and changed the boot up sequence.
Dec 28, 2007 | Computers & Internet
ASUS A*S-X not recognizing cpu
you should be able to press F2 or Del on boot up to get into the bios, but you should replace the battery first then set everything up as the cmos has obviously lost it's saved settings because the battery is flat.
Sep 10, 2007 | ASUS A8S-X Motherboard
Dell Inspiron 1501 Notebook Logo
185 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
