Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon d40 flash
My nikon d40 flash doesn't what to work. i must have touch something and now it is saying subject to dark. i have been playing around with it and i just can't figure it out. what do i have to do to get it working again? i have 2 new batteries and fully charged so i know that is not it. please help someone...
  • 1 more comment
  • magicurty Jun 07, 2008
    My D40 does not flash...
    The integrated flash pops up but no light at all...
    Is it any of the settings?
    I have even reseted the camera twice and nothing.
    Auto mode, pops when I try low light conditions but does not flash the light at all...
    I don't want to think that the light burned because defenetely this is an very unusual problem...
    PS. Camera was in the 1st day of working:(
    any solutions or tips?
  • cbrown1411 Dec 14, 2008
    I got the Nikon D40 and the flash stopped working on the 1st day :( Where can I get a replacement? I don't want to take the time to send it back. Is there a quick replacement bulb I can purchase??
  • Cameron Scott May 11, 2010
    Turn on your A/F assist and set metering to "Matrix". Check what setting you are on (Automatic[AUTO], Manual[M], Program[P], Shutter[S], Aperture[A], etc. If on P, you can adjust the exposure.
    Does the flash pop up?
  • 4 Answers
I had the same problem and found this Vimeo link that shows a simple repair to an apparent common problem. The repair worked, but understand that you will void your warranty. Don't touch the bulb as you'll get oil on it; don't touch the solder points on the wiring or you'll get zapped! http://www.vimeo.com/3141400
Posted on Nov 22, 2009
If the flash doesnt work in Auto mode when its needed and when you switch it to manual, then you need to send the unit back to Nikon to be repaired. Its a known issue with the d40 that the internal flash breaks.
Posted on Jun 08, 2008
Nikon D40 green light flashing even when off
Sorry to hear this. Dropping something on concrete creates a high G force. Can you make sure the battery is fully charged before you put it in. If you have a good battery and all it does is blink something must have been broken. I think a D40 is a rather old camera too. Sorry I do not think I can help you. In most times a LED green blinking means it is charging. When carrying a camera you should wrap the strap around your wrist. If you do it correctly if you drop your camera it will not hit the ground. It is best to keep it from dropping on the ground.
Feb 06, 2018 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 is taking Dark Pictures. Flash is
kindly see the aparture and speed of xpouser and the iso also if the iso is 100 change the iso to 400 or 800 or u can select he programme option for the best xpousers
Nov 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Wrong icon when selecting dynamic area
The D40 Dynamic area focus starts on the centre AF area then moves the focus to follow the subject.
The camera has followed something to the right and selected the right focus area.
This is normal.
You could select Single Area in the menu and move the area back to the middle using the rear AF Sensor Selector.
Jul 05, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Is a Quantaray QF30 compatible for a Nikon D40 camera?
I bought this flash on craigs list today for about 30 dollars. I did research and as long as the flash you buy is a nikon HOT SHOE mount it will work. (Look on the bottom of the flash) it will say Nikon i-ttl. I am using it on my D40.
May 12, 2009 | Quantaray QF30 for Nikon Flash
Pictures too dark. Shutter operating too slowly.
Are you in auto mode? If it is manual then it is possible that the settings are not correct for the light. You can look at the meter to see what the camera thinks about the exposure.
It sounds as if your subject is too dark. Does this happen when the area is brightly lit? Does the flash fire?
May 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Sunpack pz40X II flash - compatible with Nikon D40?
hai i think u told only sometime....
may b ur settings are not rit in the cam.
Jan 07, 2009 | Sunpak PZ40X II TTL Flash
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
R09 error message on nikon d40
It's a report saying that the camera is busy doing something. It can hapen when you have taken a photo and the camera is busy processing but I find it happens when in auto focus and the camera is having dificulty due to distance from subject or light. Try switching to manual focus, moving further away from the subject or casting more light on the subject.
Oct 29, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
1,034 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
