Question about Simplex Kaba Ilco Unican L1000 keyless lock
I have misplaced the directions on combo changing a Simplex L1011
I have the key and know the current combo. How do I change it?
3 Suggested Answers
  • 963 Answers
SOURCE: I have a 5 button
I can't help you directly, but I will steer you to further information.
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on May 13, 2011
Testimonial: "Thaks, I was able to download pdf and problem was solved.."
wentlanv
  • 710 Answers
SOURCE: Need to change the combination
Hi Don,
Got these instructions from: >>>> http://www.indra.com/archives/alt-locksmithing/hobbit.html >>>>
"Once you know the current combination, you might want to change it. Instructions for doing this undoubtedly come with the lock; but it's real easy. There is a screw in the top with a hex hole; remove this from the lock body. Dial the proper combination, but don't move the handle. Press straight down through the hole with a small screwdriver, until you feel something go "thunk" downward. The lock is now in change mode. Reset the tumblers [leftward twist], enter your new combination, twist the handle as though opening the lock, and your change is now in effect. Re-insert the screw. This does the following: The thing you hit with the screwdriver pushes the tumblers down onto the locking bar [which is why the proper combination must be entered], and disengages them from their idler gears. Button presses turn the *idler* *gears* around, and then the opening action shoves the tumblers back up to mesh with these gears in their new positions. A subsequent reset mixes the tumblers up again to follow the new combination. This description is admittedly somewhat inadequate; the right thing to do is take one of the locks apart and see for one's self what exactly happens inside."
Hope this helps. If it does. I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 16, 2011
Where can we order the key to change to combo?
A Df-59 key can be purchased through this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx Call them to order it @773-809-3667 Obviously it isn't really $0.
Or try this source:
http://www.ckilock.com/Mpage18.asp
The tenth item down is the key & spanner wrench for $9.
Mar 12, 2012 | Simplex Kaba Ilco Unican L1000 keyless...
Lost the df-59 key and need to change the combination
For $9 you can get the df-59 key and spanner wrench from this company:
http://www.ckilock.com/Mpage18.asp ,10th item down on page
C.K.I. Wholesale Lock Supply 1-800-445-5230
Their item number SMPBC201278
Hope this helps!
Feb 22, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex 1000 lever handle when correct combo put in lock combo lock operates fine except unless you let the lever snap back lock dose not reset in locked position, in other words if you slowly let the...
I don't have a direct answer, but here is the contact info you need for customer service:
1-800-849-8324 (option 1)
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Tech Support is probably your best bet!
Aug 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Forgot combo
Go to this page for starters (you can copy and paste it into your browser):
I don't know if you are dealing with the Model 1000, L1000, or LP 1000, but regardless, you'll see a grid for these various model on this page. The information you need is most probably under the rightmost column, TIPS. When you click on that you'll pop up a further choice of how to change or reset the combination.
You will find that you need a DF-59 key as part of the process. I believe a Df-59 key can be purchased at this site:
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
Jun 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I have a 5 button simplex lock with a arm bar opening lever inside the door. how do I change the combo?
May 09, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
If the wrong combo is entered into my simplex Unican 1000 series Keyed lock the locking mech. will not reset unless I open the lock and manually move the levers. How Do I correct this so the lock functions...
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
Apr 22, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I need to change the two numbers I have set. How does one go about totally changing the numbers that have been set?
http://cc.bingj.com/cache.aspx?q=Simplex+1000%2fL1000&d=4586539907550160&mkt=en-US&setlang=en-US&w=9c67dfe6,2fb6a508
That is the Kaba webpage that deals directly with changing the combo of youir particular safe.
Jan 31, 2011 | Kwikset UltraMax Powerbolt 1000
I am trying to change the code on my 1000 lock but do not know what a spanner wrench looks like? i just started this job and dont seem to have all the things i need to change the code.
Jan 28, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need to know how to reprogram the code on a Simplex Kaba IIco Unican 1000 keyless lock
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
aspx?id=13
Good Luck!
Dec 05, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Need instructions on changing combo
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O’CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O’CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O’CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
Aug 04, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  L1000 keyless lock  Logo
292 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
Pamela Leach
Pamela Leach
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
