Question about HP OfficeJet 7110 All-In-One Thermal Printer
All lights flashing on 7110 All-In-One
I rcvd printhead cyan error. I ordered and replaced and now the message keeps saying turn power off and back on and all the lights are flashing. I have turned off and on and unplugged numerous times but as soon as it comes back on all lights blinking. how do I reset the printer?
  • kimby12000 May 11, 2010
    The semi-full reset worked like a champ!
    Thank you sooo much.
    Brigadier General:
  • 3,917 Answers
Hi
The Lights flashing can occur if there is a power problem, paper jam or the Front panel overlay was not seated properly.
Try these steps :
1.Change the power source and if the All-in-One is connected to a surge protector or UPS, disconnect it and connect it directly to the power source.
2.Check for any paper jams by the rear access door.
3.Remove and replace the front panel overlay.
4.If the problem is the same, reset the All-in-one :
Press and hold # and 6 while plugging in the power.
Semi-full reset should be displayed on the screen.
Before resetting it, back up any faxes in the log as this step will clear the fax memory.
Let us know if you want to know something more else accept the suggestion.
Thanks for contacting fixya.com
Posted on May 11, 2010
    I tried all of your suggestions and the outcome is the same. The lights are all still flashing and the display still reads turn power off and on. Any other suggestions?
    I tried the semi full reset again and I pressed buttons until machine restarted and it is working now. Thanks.
    PS - you might want to add this step to your directions, but you were very helpful!!!
Error 1252 power/on and off
System Error: System Error 125x: Sub-Tank Supply Error
Problem
Description:
The Sub-Tank Sensor does not switch to less than half even though ink has been
consumed.
x = 0: Printhead Number 1 (Black).
x = 1: Printhead Number 2 (Light Magenta).
x = 2: Printhead Number 3 (Light Cyan).
x = 3: Printhead Number 4 (Yellow).
x = 4: Printhead Number 5 (Magenta).
x = 5: Printhead Number 6 (Cyan).
Corrective Action: Try the following:
Enter the Motors Menu (in Maintenance Mode) and set the "Solenoid L"
and "Solenoid R" options to "Closed" to cut the outside air. Now set the
"Cap Stat Motor" to "Prime" to discharge the ink from the Sub-Tank and
check if the Ink Supply Motor drives by turning the power ON again when
there is a little bit of ink left. If the Motor is not driven, replace the
corresponding Cable or Ink Supply Station.
Check whether the Sub-Tank Sensor Plate works correctly and is not
blocked by any foreign object.
Apr 18, 2013 | HP DesignJet 9000 InkJet Printer
HP5500 UV...after paper jam I have a replace lt cyan printhead message and recover black printhead.
The Lt Cyan printhead may have been damaged by the paper jam.
I recommend removing all the printheads and power cycling the machine (turn off then back on) Install the printheads and check that each one says OK. Replace any that show recover or bad. (HP will replace free if it is under warranty - return it to the store you purchased it from)
Nov 15, 2011 | HP DesignJet 5500PS InkJet Printer
Have a brand new printer not used till now, cyan/magenta printhead light and the light for the power bottom both flashes, and a message appears (printhead problem - the following printhead has a problem...
this sounds simular to the photosmart C7250 ink system failure. which cause by air in the lines. and we fix this by reseting the printer and it redoes the cartridge installation. thus pushing all the air out.
Dec 24, 2010 | HP OfficeJet Pro K8600 Printer
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
I have three HP L7780 printers that have bad print heads black/yellow. replaced but same problem. ?????
take out printheads. unplugg power cable from back press adn hold down 6 and # buttons on pritner at same time while holding them down plugg it back in. then insert printheads one by one. first insert black/yellow shutt the door adn check for message on pritner screen. if it says printhead missing cyan/megenta it means it detected black/yellow printhead. do same with cyan/megenta adn check for message on screen. if you see no error mesage and both printheads were detected fine let the printheads alligned completely. then if u see same issue it is the pritner whgich need to be replaced.
Dec 15, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
My HP Officejet Pro L7780 All-In-One InkJet Printer was jammed with paper. I believe I got it all out and now the display reads" Printhead problem- the following printhead has a problem: magenta/cyan...
There are two possibilities here Joanne, first, it could be a false error message or else second, the Cyan/Magenta print head has gone bad.Try the following:
1. Take the Cyan/Magenta printhead out. Remember, the printhead...not the cartridges.
Clean the copper contacts with a Q Tip, moistened with plain water. Wait till it dries, put the printhead back in.
2. If this does not resolve the issue, unplug the power cord from the back and press and hold the power cord for 30 sec. This will drain all the static charges. Plug it back after a couple of minutes and see if the error message re appears.
Jul 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Print head error message
reset it in window printing menu. perhaps it works.
Dec 03, 2008 | HP Business InkJet 2800 Printer
The following printheads has a problem
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 25, 2008 | HP Officejet Pro L7680 All-In-One Printer
Bad cyan printhead
try to clean with tissue will mostly solve if does not solvethen go for replacement.rate this as fixya to encourage us to solve more and more problems like yours.good luck.
Jun 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hp Officejet 7110 Not Printing From Computer
HP 7110 Printer
The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
HP OfficeJet 7110 All-In-One Thermal Printer Logo
390 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
