Question about Garden
Need a manual for a Weed eater WER500 17" rear tine tiller
5 Suggested Answers
  • 10865 Answers
SOURCE: need manual for mtd 5 horse rear tine tiller model
If you go to Sears.com, then go to parts,then type in the model number, then look to the right and scroll down slow you will see a spot that says get manuals for this model and click on view manuals then any manuals they have you can print them out.
Posted on Feb 27, 2009
  • 221 Answers
SOURCE: mtd rear tines tiller won't engage tines. F and R
It sounds like the shift shaft or something in the gearbox the shift shaft engages. I know you didn't want to hear this but it is not uncommon. Most operators don't use the clutch bail when starting, stopping, and shifting as they should.
I hate to say it but this may require a trip to your service center for repair.
Posted on Apr 30, 2010
SOURCE: sears rear tine rototiller 32-29978 manual
I have a sears rear tine rototiller 7 horse 17" and the left side tines do not turn but the right side does
Posted on Apr 10, 2011
SOURCE: tiller tines won't turn where put in gear.
The spring goes in first followed by the ball. The ball should not get in the key way because that is filled by the slider pins that go up into the spur gear that drives the tines. Actually the slider pins drive all of the gears by engaging different gears as the gear collar is moved up and down. The detent spring and ball is the mechanism that is supposed to hold the the clutch collar in place. Mine jumps out of gear when tilling any depth except very shallow. I have reinforced the shifting forks and replaced the pins on the end of it. I believe that the pins wear and the arms spread because i have to keep pressure on the shifting rod or it will jump out of gear when tilling. Even with the reinforcing, pressure on the shifting rod will wear out the pins on the shifting arm. This will be my 3rd reassembly and I am leaning toward the detent spring being weak and allowing the shifting collar to move too easily. I may order an new spring and ball and see if that helps. I am getting pretty good at taking it apart.
Posted on Apr 16, 2011
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
I am in need on line of the owners manual for troybilt "8-hp Horse" tiller and fluid capacities and type/weight of oil used in front transmission and rear tine gears. Thank you, Sincerely, Wm....
This is as close as I could come to your exact model from this site. This is for a 8HP Briggs Horse model with rear tines. I hope this can help you. This site (the manuals site) needs to update to newer models. First a link to the site I use and secondly, the PDF online file of the 8 HP Tiller for you.
http://www.manualsonline.com/
http://dl.owneriq.net/7/7ba1d4f6-61b9-4c56-b878-fcfa51ddfeef.pdf
Apr 12, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
Water in the gas
go to partstree.com see if you can find a pic to help you.let me know,ok
Jul 20, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Ariens rear tine tiller. What direction are the
The tines should turn counter clockwise or from the ground up toward the tiller not toward you .Owners manuals can be obtained from a local dealer on most often on line..
Apr 09, 2009 | Ariens Garden
I need a mannual for a craftsman 5 h rear tine tiller
Try this website.  http://c.managemyhome.com/mmh/ You will need to register.... and go to home page... manuals.... put in Craftsman and serial number. Pdf should come up, you can download or print.
I worked for me on a mower manual that no one could track down
Hope it works for you
John Elsegood
Apr 06, 2009 | Craftsman Cultivating Shield
Need manual for mtd 5 horse rear tine tiller model 135202 need to know how to change chain
Feb 27, 2009 | Mtd Bronco Rear Tine Tiller
Garden Logo
683 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
