Question about Coleman Powermate Premium Plus 6250W Portable Generator
Need new gas tank
About a 20yr old generator
gas left in it that long after running only 2hrs.
looks new except gas tank is full of rust.
thanks
  • 905 Answers
A couple things you can do here...
1) Drain the tank, blow it dry using compressed air, and get all the rust out that you can. Use an acid wash / rinse to help remove the rest of the rust. Coat the tank inside with a tank sealer like that from kbs-coatings or caswell.
2) Have a metal shop make you a new tank that will approximate the old one.
3) Install a fuel filter that will catch the rust particles (left over after blowing it out) and be done with it
4) Use an external fuel tank (marine comes to mind) instead of onboard fuel tank.
Posted on Jun 12, 2010
Ihave a dp6500 es generator runs fine on full choke
A partially plugged fuel line. Look in the gas tank to see if it's obstructed.
Oct 22, 2016 | Electrical Supplies
1330se it is brand new not getting fuel to motor will run on either
There may be a filter on the fuel pickup line inside the fuel tank that has clogged due to old fuel being left in the tank. Look inside the tank - it probably looks like rust - you need to change that. Any lawn mower repair shop should have a filter that works and could change it for you. Note - run the blower until it runs out of fuel before storage to avoid problems like this - same rule for lawnmowers, weed wackers, etc.
Jan 20, 2014 | John Deere Garden
Gas tank leaks is rusted inside and out am looking for a replacement tank
find a honda dealer and pray its not expensive... Or find a small engine shop and see if they have some junk generators laying around and buy the best tank they have and make it work...
Dec 27, 2013 | Honda Eb3500 Eg3500 Em3500 Ew140 Generator...
Generator does not start it has fuel in the tank with new battery ,check every thing is ok
how OLD is the gas? if it is older than 3 months with NO stab condishner get rid of it try new gas
Dec 12, 2013 | Dewalt Generator. 6000 Watt Portable...
Eu1000i runs and cuts off.....pump is good
If you haven't had it started for a while and have left gas in it, you probably have old/bad gasoline. Drain it and put new gas in. It may have clogged the fuel filter with rust and sediment from the old gas. Next time, put "Sta-bil" in it when you store it for the season, it will stabilize your gas.
Jun 21, 2012 | Honda Generator Cover Eu1000i Camo
My powermate 5000 with subaru engine will run anywhere from 30-60 minutes and shut down. One light pull to the pull start and it runs great for another 30-60 minutes. Never a problem to start it back up...
There is debri or dirt in gas tank and eventually it gets sucked up and clogs the screen filter on the end of gas line. Drain gas tank and flush out a few times. let dry and put new gas in it. check your gas can, if it is metal, it may have rust in the bottom of it and it goes in the gas tank and clogs screen, make sure you have a clean gas can that you use to fill the generator.
Aug 25, 2011 | Coleman Powermate Subaru 5000W Portable...
2001 Olds Silhouette: plenty of gas in the tank but the gage will read full, 3/4 full, 1/2 full, and everywhere in between. Van runs fine. No other issues except the gage goes crazy and can't depend on...
2000 Olds Silhouette: plenty of gas in the tank but the gage will read full, 3/4 full, 1/2 full, and everywhere in between. Van runs fine. No other issues except the gage goes crazy and can't depend on what it says. ...
Aug 12, 2010 | 2000 Oldsmobile Silhouette
I need to remove the gas tank from a honda generator eu3000is.
I have a ems 4500 honda, the gas tank looks like the upper bar needs to be removed to get the gas tank off, it does. Follow the
top bar down on each of the corners. Where the top bar meets with the bar below the gas tank, you will find a bolt in each of the tubes. Take these screws out, use a hammer to tap the top bar upward lightly at each corner. You should see the tubing sliding up out of the bottom tubes.
Apr 10, 2009 | Electrical Supplies
Looking for manual for generator...won't start
I had the exact same problem. There a few things you need to do first.
1) Make sure the fuel line knob is turned to the Open position; this knob is located under the gas tank.
2) Turn the power switch to on : it is a little red switch located near the pull-handle on the front of the generator. It needs to be on 'I' not on 'O'
3) Turn the choke lever on: it is a little steel lever with an arrow at the tip. Move the lever in the direction the arrow is pointing.
4) Make sure you have gas left in the tank: it may have evaporated or gummed up if you did mix in a fuel stabilizer before putting it away for storage.
If none of these things work , then you carburator may be full of water and gas lines gummed up.
These Gens need to be started up at least once a month to make sure they keep working properly.
Fred
Sep 28, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
176 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
