Question about Home
I have a Thetford cassette electric toilet model No PP C2 L and the flush does not work, I have changed the fuse but still cannot get it to work. Can I get a manual or any help??
muralme
  • 20 Answers
SOURCE: toilet keeps flushing
you need to replace the flapper, it's allowing water to seep thru
Posted on Jul 12, 2009
SOURCE: need take out thetford toilet of ace award
can anyone tell me where is the fuse fits under a thet ford cassette toilet model ppc2r and wot size
Posted on Jul 20, 2009
bearsfan7538
  • 119 Answers
SOURCE: I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
Posted on Nov 15, 2009
  • 37 Answers
SOURCE: my saniflo plus keeps tripping the fuse when the
Problem is water in the electrical chamber, either scrap it if is over 8yrs old or call a sani engineer to repair it.
Posted on Feb 26, 2010
  • 37 Answers
SOURCE: saniflo toilet top2
Sounds like you have blockage in the discharge pipe
Where is fuse for thetford toilet cassette
This is quite difficult and fiddly. The fuse unit is situated above where the cassette gets inserted. Remove the cassette and at the top front left hand side you will see the wiring in the cavity. This will give you access to the fuse unit and reed switch. I am assuming the toilet won't flush. If this is the problem then the answer is above. If the problem is the light will not illuminate when full then it is the reed switch that needs replacing or by passing. Hope this helps.
May 16, 2017 | Camping, Backpacking & Hiking
How do you Clean out algae in toilet water holding tank
Walmart sell aglaecide for swimming pools and hot tubs. I'd use that first. After algae has died, scrub inside of tank lightly and flush a couple of times.
Aug 06, 2014 | Thetford 33203 Sliding Cassette Cover Gray...
We have a thetford C200cs on the motorhome we have just bought (2003). No water seems to pump, & the blue flush button doesn't seem to work. Are there any instructions availabe? The fuse has been...
Red light is just a reed switch that turns on the LED when a floating magnet inside the cassette floats up (when the cassette is full) and switches on the reed switch thereby switching on the LED. It just tells you the cassette is full and you need to empty it.
I'd say either your button or electric valve is broken. All the button does is allow the electric valve to break the seal that allows water to flow from your onboard water system.
I'll assume that the water in the rest of your motorhome is working?
So check the switch first.
You can lever off the switch/LED panel and remove the square connector from the back of the button. Get a multimeter and set it to either Continuity or Resistance (Ohms). Place the connectors on 2 of the switch pins and press the switch (the switch is actually 2 switches with 4 pins, but each pair of pins is connected together) - if you get a beep (if multimeter on continuity) or low resistance reading (if on resistance) then the switch is working - if this is the case then it's probably the electric valve. If the switch is not working, then that's your culprit.
When you replace the connecter you can replace it either way round.
Feb 01, 2010 | Thetford Porta Potti
Hi our thetford cassette toilet (c200)blows the fuse every time we touch the flush button.can anyone please help. WE have only had the caravan for two days and has never worked. THANKS
Probably the rotor has come to a stand still (carbonade). I suggest you will clean the rotor with an house-hold acid liquid (like the one for cleaning coffeemachines).
Flying Dutchman.
Jan 17, 2010 | Thetford Porta Potti
Toilet won't flush. New pump fitted fuses ok.
Thetford Model Cass C2 L TC WHI - Toilet won't flush. There is power to the switch and flasher. Any ideas?
Jul 30, 2009 | Thetford Porta Potti
Electric diagram c2
go to thetford main site, you can download all manuals and diagrams
Jul 02, 2009 | Thetford Porta Potti
Flushing knob on a C2 Theford cassette porta potti hard to turn
Hi! Spray blade which closes holding tank with silicone spray. Make sure spray goes under lip of sealing ring. Also spray around holding tank actuator knob allowing to penetrate underneath to shaft. Don't use a silicone grease as this will gum up the works. If you can't get hold of a light silicone spray try using household type silicone polish intended for furniture. Wipe off any surplus as only thin film required.
John Long
Jun 07, 2009 | Thetford Porta Potti
Im trying to find the wiring am for a thetford C2 porto potti
Go to www.thetford.com.
Click Customer Support then Product manuals and download manual in PDF format.
Wiring of C2 has fuse, safety switch, flush switch and flush pump in series. If fuse is blown you probably need to replace pump. Instructions come with replacement pump.
Jun 04, 2009 | Thetford Porta Potti
Casset toilet will not pump water for flush
Open door, remove toilet cassette unit, look in under flush water tank, observe a short metal blade that actuates a safety switch. This is between two plastic guides. Now look just outside the right hand guide. There you will find the fuse which is a standard blade type. Just pull it down to remove from holder. You will probably find it rated at 3 amp. If it is blown you will probably have to replace pump. Looks difficult but is actually dead easy. Instructions come with replacement Thetford pump. Only problem you may have is a perished sealing ring on the paper holder cup which is no longer available as a spare. Just use a good quality outdoor type sealant as a replacement. Be sure to recover any bits of broken ring from the flush water tank as these can be drawn into your replacement pump and cause it to sieze. At minimum this will cause you to say bother! Happy repairing.
May 27, 2009 | Thetford Porta Potti
Need take out thetford toilet of ace award
Apr 27, 2009 | Maximum Thetford Porta Potti 365 Portable...
Home Logo
277 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
