Question about Kenmore 54602 / 54604 / 54609 Side by Side Refrigerator
Refrigerator warm Hi, Kenmore elite fridge, model # 106.54606300, freezer works fine, fridge however only down to 30s overnight when coolest in the house...otherwise 40s-50s.  air coming in on the top left of the fridge so i think that's fine, only some ice on coils in the freezer and thawed that out this am (minimal).  fans all working.  gotta believe its the defrost heater, timer, and/or thermostat but don't know where to find those or how to determine one or the other.  please help...don't have the money to call someone in to fix right now.
    President:
  • Kenmore Master
  • 2,651 Answers
This particular model has onlya defrost thermo and heater. the defrost timer is actually built into the electronic control.behind the kickplate there should be a tech sheet to aid in r\troubleshooting the unit.all are a little different but youll be able to go into the electronic control andtest the parts indivually. all you reallly need to do is "force a defrost" cycle.
if need be a continuity test can be preformed on the defrost thermostat( clipped onto the the top of the evaqporator coil) as well as the defrost heater which is also located in hte evap section ( its wrapped around the coil(u-shaped element) heater should also have continuity.
defrost thermo IS the MOST common issue with any defrost problem. heres a link to sears.com gives a location as well as part numbers if needed 35is thermo and 33 is the heater
Posted on Mar 29, 2008
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a fridge that was made in 1995 that the fridge stays warm freezer works fine I also can not fine a model @ that I can read
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer working fine, refrigerator part warm, can I possibly need freon?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 10, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Refrigerator is at80 degress
This unit uses the cold air from the freezer to cool the fridge, you will find that the air duct has frozen up, completly defrost overnight with the doors open, this should rectify fault. Regards Advisor
Mar 06, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 54602 / 54604 / 54609 Side by Side Refrigerator Logo
159 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
