Question about Cameras
Control Button Problem
Sony DSC-W230 displays ''no memory space on internal memory'' when powered w/o memory card. It will take pictures using a memory card but no control functions except flash options respond. Power button and shutter buttons work OK. Pictures on the memory card can be read via. a card reader.
Any recommended fix?
  • dl May 14, 2010
    Disassembled case, removed and cleaned ribbon cable connections between control panel and camera. Deleted pictures on internal memory. Works OK. Thanks for the generic control button problem hint.
    Brigadier General:
  • 11,967 Answers
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory and then promise yourself to never use it again.
Posted on May 11, 2010
How to transfer internal memory pictures on a DSCW70
Unlike most brands/ models of cameras, the Sony CyberShot (DSC) cameras feature internal memories, (not enough to hold sufficient data). If you took a few shots before inserting the memory card, the pictures are stored in the internal memory. You can transfer/ delete those pictures by the following steps.
1. switch off the camera,
2 open the battery/ SD card slot cover and remove the SD card.
3. close the cover and switch on
4. press the display/ preview button and your picture should be visible on the screen.
You can now do whatever you want with your picture.
Does this help? Please provide some feed-back if my answers do help.
Sep 09, 2014 | Sony Cyber-shot DSC-W70 Digital Camera
Cannot upload pictures anymore from sony DSC-W230 camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 17, 2012 | Sony Cybershot Dsc-w290 W230 W220
No memory space in internal memory. What does this mean?
This camera has small internal memory like 32MB to store few pictures and shows no memory space message after storing these few picture files.
You need to insert memory card in camera and go to menu and select Copy option to copy internal memory images into memory card then take out memory card from camera and delete internal memory pictures one by one or perform format memory to delete all of them at once.
Sep 30, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
I means you are saving your pictures to the internal memory instead of the memory card. Move the pictures to the card and put them onto your computer. Once you have them out of internal memory, format the memory and select external storage in the setup menu.
Jan 09, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
No memory space on internal memory. How do I fix
Stop using the internal memory and insert a memory card.
Dec 27, 2009 | Sony Cyber-shot DSC-W180 Digital Camera
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
How do you get pictures from internal memory to memory card on
First, insert a compatible memory stick in the Camera then turn the Camera ON.
Then, press the Menu button to display menu items.
Then, use the control button to select Setup option.
Next, select Memory stick Tools > Copy.
This will initiate copying contents from the internal memory to the memory stick inserted in the Camera.
Oct 16, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Took pictures with sony cybershot DSC-100 and then realized I did not have the memory stick in there. How do I get the pictures out of the camera and either onto the stick or computer? Thanks.
Please inster memory card in camera, power it up and go to Menu>>Copy>>OK
That will copy pictures from internal memory to memory card.
Apr 03, 2009 | Sony Cameras
No memory space in internal memory-no more pictures can be taken!
there may be two problems. 1. Format your card before using it. 2. Switch your storage device to memory card and it will work. Hope it works..:))
Mar 10, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
DSC-T1 model has no internal memory and it requires memory card due pro to store pictures.
Oct 24, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
