Question about Refrigerators
Compressor clicking on and off fridge now warm
I have a whirlpool ss25aexhw01 and i have a bad ptc or starter relay and overload switch. the replacement kit only has 2 connectors on starter relay where old one had 3 connectors. mine is the one that requires a capacitor so i am not sure how to connect the capacitor into the mix. any ideas?
  • supervegie Mar 29, 2008
    yea thats the one i bought, some sites show it with 2 and some show it with what looks like a third one. i am wondering if the jumper in the kit has something to do with it. spoke to a different reseller and he told me right part he told me if i bought the kit he would revile the secrete. the picture i see shows no hook up for cap. but looking at jumper it looks like it was designed to also plug something in top but don't want to fry system experimenting.
  • supervegie Mar 31, 2008
    I took it to a different repair shop and verified it was the correct part. they were as confused as me as to how to wire in capacitor. the diagram shows the cap wired in series to capacitor. but they said it was correct part.can i paste an image in here or is that not allowed?
    President:
  • Refrigerators Master
  • 2,651 Answers
Looked up your model number and got a part number of 8201799. is that the number you got??? cause in the pic it looks like there are 3 terminals on the relay(brown piece) there should have also been instructions in the package no???
Posted on Mar 29, 2008
  • Ron Coons
    Ron Coons Mar 30, 2008
    the jumper is probably in case your terminals are not correct size, a small to large connection.
    O.K. assuming thatth erleay has 3 terminals ( 2 on left and 1 on rght) and 1 wire terminal on the white overload .
    white overload is your power in red or orange wire usually
    the relay is wired as such
    the white(nuetral) wire is bottom left and the capacitor is wired top left and bottom right
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
My Kenmore side by side freezer and fridge sides are warming.
your ptc overload/relay on the compressors bad,unplug the unit and remove this ptc part off the compressor and replace it
May 02, 2012 | Kenmore Side by Side Refrigerator
Fridge side cold freezer not. compressor seems to be short cycleing
if theres a clicking noise behind the unit,then the ptc overload relay is weak and dropping in and out which will short cycle the compressor, also a compressor thats going bad will draw excessive current and make the ptc drop in and out check start and run currents to determine this,also,but rare it could be the cold temp control
Feb 23, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My whirlpool american fridge s20BRBB20 A/G clicks and clatters and front panel flashing. Fan and motor changed but problem persists
if the clicking is from the ptc overload relay on the compressor unplug it off the compressor and replace it,if the clicking is coming from the main control board and the front readout is flashing/strobing the board is bad,but before you replace this board make sure there are no inopertive fans as this will ruin a new board immediately
May 13, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
THE LIGHT COMES ON INSIDE THE FRIDGE, THERE IS STILL SOUND BUT THE FRIDGE IS NOT COOL AND THE FREEZER HAS DEFROSTED.
either the evaporator coil in the freezer wall has iced up and cant blow cold air and needs the defrost heater and thermostat checked(hint:rear wall of freezer will have snow/ice/frost on it)if this is the problem,otherwise the ptc overload relay on the compressor is bad and the compressor cant run correctly,if it just keeps warming up,then this is the culprit and a new ptc replacement easily plugs in where the old ptc was
Jan 09, 2011 | Baumatic BF230 Top Freezer Refrigerator
Does not cool
one of 2 issues,first possibly the evaporator coil in the freezer is iced over and not allowing cold air into the freezer and refrigerator,then check the defrost heater and thermostats on the evaporator coil/secondly,it could be a bad ptc overload relay on the compressor in the rear lower area not letting the compressor start,when you check this the condenser fan near this may be running,don't let this fool you it will normally run even if the compressor is not,a hint,if the compressor is overly warm to the touch this is a sign of a bad ptc overload relay remove this component and shake it by hand,if you hear it rattling its another sign its bad
Nov 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My 12 year old Whirlpool 167cm Free Standing Fridge Freezer has stopped working. There is still power to it, since the light comes on in the upper fridge compartment? Has the compressor gone? Coventry...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jan 10, 2010 | Refrigerators
Whirlpool fridge not cooling gone warm air blowing
more than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Jan 16, 2009 | Whirlpool GS6NBEXR Side by Side...
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Kelly
Jun 18, 2008 | Refrigerators
Whirlpool gd25sfxhs03
That click maybe you compressor cycling on its overload pertector... see if compressor is evern running..listen for a click there  .it maybe a bad relay on compressor
Oct 31, 2007 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
549 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
