Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Lost code for GX B0709 Safe
The safe is located at work, and was used a few years ago to store keys in. Nothing really critical.
As the safe has not been used for quite a while, no-one can remember the correct code and the battery seems to have gone flat.
Is there any way the safe can be opened, and code reset so can be used again ???
4 Suggested Answers
  • 313 Answers
SOURCE: battery flat lost keys how do i open safe
Most of these safes come with a default setting. Try entering 0000.
otherwise you will need to locate the serial number and contact the manufacturer.
Posted on Jul 25, 2010
SOURCE: The wrong number was input and now we can't get
You don't know the combination code, and you don't have a key? Or you know the right combo code, but the batteries are dead? If you have the right code, and the batteries are near-dead, try the jiggle suggestion...put the safe on you lap, put in the correct combo, and jiggle the safe while turning the latch. Might work.
Posted on Feb 17, 2010
  • 11 Answers
SOURCE: I HAVE A SMALLN GX B0709 SAFE. THE BATTERY HAS
I put mine on top of the AGA to heat it fro an hour. This brought the batteries up enough to open the safe. Sounds weird but it worked!
Posted on Mar 14, 2011
I have a Namson SFT-25EA electronic safe, batteries dead, can't remember where I stored key, can I get into it and be able to re use or do I need to force my way in
A "Trouble key" has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
Feb 15, 2017 | The Home Security
GETTING IN A SAFE
You really have no choice but to break in or call a locksmith.
Sep 23, 2016 | Liberty FatBoy Jr. LFJ48 48-Gun Safe,...
Have a pro safe psd 80 safe. Lost keys and a few years ago and couldn't get into it. Needed to retrieve passport. I took it to a locksmith who had it for about a month and he finally got it opened. C
Contact www.sentrysafe.com. There SHOULD be a code/numbers stamped on the inside of the safe. With those codes, a dupicate key can be made. A locksmith took a MONTH to open it??? Wow. Should have taken about 15 minutes.,,.
Nov 05, 2014 | Home Security
Where can I get replacement keys for GX B0709 digital safe
There might be a code on the key lock. Manufacturers can sometimes furnish replacement keys by the code or serial number of the safe. A locksmith could also pick the lock and make a key. Keys are really essential if the electronic lock fails. If the safe needs to be opened without keys, a pro can do this with minimal damage.
Aug 06, 2014 | Safe International Digital Electronic Safe...
Battery flat lost keys how do i open safe gx b0709
Jul 25, 2010 | Safe International Digital Electronic Safe...
The wrong number was input and now we can't get into the safe, we don't have a key for it, and the batteries seem to be flat. What can we do? The safe is an electronic digital safe GX B0709
Feb 17, 2010 | Safe International Digital Electronic Safe...
I HAVE A SMALLN GX B0709 SAFE. THE BATTERY HAS GONE FLAT, AND I HAVE LOST KEY. PLEASE SEND SOLUTION IF ANY.
Jan 05, 2010 | Safe International Digital Electronic Safe...
I have a digital electronic safe home protection. I have lost my keys and the battery is dead I have had thi safe for nearly 2 years
1) look again for the key
2) call a lock smith
3) drill the lock
these safes arent expensive , cheaper to drill the lock and replace that a lock smith , but get a quote
Oct 09, 2009 | Safe International Digital Electronic Safe...
Sentry Safe A3819
Go to
http://www.sentrysafe.com/customerCare/OwnersManuals.aspx
Find your model (pobably in safe for business)
And download the manual
Good Luck
Dec 23, 2008 | Sentry Fireproof Safe
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
366 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
