Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
3400 series werlitzer 1970 jukebox
The turntable that holds the 45s wont turn when a selction is made.i need a local repair man in denver area
  • gtmac Apr 22, 2008
    When a selection is made the systems sounds like it wants to turn but locks-up and does nothing. The turntable and actuatingarm(picks up the records) do not move.
The selector for the wurlitzer 45rpm will not select a record, when you put the money in the wheel just keeps going round and will not pick up.
Posted on Apr 29, 2011
    Champion:
  • Wurlitzer Expert
  • 211 Answers
Look in the back. If you 'pop' a pin on the selector ring (press at the bottom of the small springs) so it pops up and the machine then plays o.k. then it is probably a bad contact in your keyboard leaf switches. Run a stiff piece of paper or card between the contacts to clean them.
If it doesn't play, then you have more complicated problems.
Posted on Apr 03, 2008
  • Dave Jukebox Apr 23, 2008
    Just a thought. Check that the crank arm that sweeps round and hits the pins isn't jammed on a pin.
LOUD HUMMING NOISE COMING FROM SPEAKERS
Could do with a service.
Check the turntable motor and drive plus check the cartridge and signal wiring.
Sep 14, 2017 | Wurlitzer Jukebox CD Player
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
I have a Rowe R-89 jukebox. Even though the motor is turning on the turntable, the turntable is not moving. Should there be a washer on the turntable base to elevat it so it will turn?
Hello Robert,
You say you have a R-89 jukebox and the turntable motor is running, I assume that the pulley on the top of the motor is clearly seen turning. Is the turntable belt loose or missing?
From your message I am not sure that your jukebox is a R-89, could it be a 1978/1979 R-82 or R-83 that uses an idler wheel.
On this model the turntable motor is 110 volts AC.
If the above is true check that the idler wheel and the linkage spring is pulling the idler wheel against the turntable and the motor shaft.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
Aug 19, 2010 | Wurlitzer Jukebox CD Player
My Wurlitzer One More Time needs repair
I would post a request for an engineer in your area on the following jukebox forums:-
www.phonoland.com
www.collectingbanter.com
www.jukeboxmadness.com go to the forum section
www.arcadecontrols.com go to the forum section and pick jukebox
Regards
Alan Hood
ami-man
UK
May 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
Carosel doesnt turn on rowe ami r-82 jukebox
First check to make sure you are getting power to the drive system. If turntable is belt driven, check power to drive motor, then check the belt. Otherwise it is direct drive, which means the turntable is connected directly to ths motor and the motot will have to be replaced.
May 16, 2010 | Audio Players & Recorders
Need to make hole bigger on a 45 record
I am aware of jukebox mechanisms that would clamp down on the record, and if it detected a small-hole in the 7" disk, it would change the RPM to 33 1/3, and the large hole would mean 45 RPM.
However, if we drill down into the history of the development of the 45, we can see that it was developed as a replacement for the 10" 78 RPM disk. It was also intended to be played on a distinct 45 RPM player, and thus the large hole to discourage use on regular turntables.
Most of the 45s in the UK had a pushout centre (some round, some triangular). 33s didn't have this. Ex-jukebox records had the pushout pushed out, and clip-in new centres could be fitted
Mar 16, 2010 | Audio Players & Recorders
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wont eject disc
Ouch!
1. power OFF
2. UNplug cord at wall
3. Turn ON jukebox (w/o power cord plugged in)
4. Turn OFF jukebox
5. Plug cord into SURGE PROCTOR (not wall, not simple power strip)
6.Turn ON jukebox.
7. If it doesn't work, try once more; otherwise ... *sigh* repair/replace..
Sep 01, 2009 | Audio Players & Recorders
The arm on my 1015 Werlitzer will not reset itself.
THE GEARS OR OUT OF LUBRICATION.
LUBRICATE WITH WHITE LUBE GREACE.
THEN TURN THE KNOB ON THE GRIPER ARM
TO RAISE, AND LOWER THE ARM. THE ARM IS STUCK.
DOCTOR FIX IT
IN-HOME JUKEBOX REPAIR
6362273300
BALLWIN MO.
Feb 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have a old antique wurlitzer and the records are playing very slowly what can be causing this
Bad drive belts.
Motor needs servicing (most likely).
Hasn't been converted for 50 Hz.
Dave F.
Nov 26, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
205 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
