Question about Refrigerators
GE PSS26P FREEZER WORKING FINE FRIDGE SIDE SET AT 37 AND STAYS 44 TO 45 DOESNT SEEM LIKE THE FAN IS KICKING ON
  • rayclements May 11, 2010
    WILL TRY THIS SOLUTION FIRST THANK YOU
    President:
  • 949 Answers
The problem is due to air not flowing from the freezer (where all the cooling coils are located) to the fresh food section. This could be due to a couple things.
First look in the freezer section behind the food and shelves to the back panel, what you want to see is if there is a frost build up. If so then we have a defrost problem, as these units are suppose to turn a heater on every 8 hours or so and remove the frost from the coils, if this does not happen frost will block the air flow through the coils and even stop the fan. If you have frost there, unplug the refrigerator, take everything out of the freezer and take the panel off of the back wall inside the freezer. Unthaw the ice and frost, you will see a heater just below the coils, that will most likely be the culprit.
If you do not see frost the fan has most likely failed, the fan is located just above the coils we described above.
The last thing I will mention and check this first is the condenser coils (these are the coils on the back or under the refrigerator, make sure they are clean and if you have the coils under the refrigerator there will be a fan down there that should be running too.
Let me know if you have questions about any of this.
Posted on May 11, 2010
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
My GE fridge PSi23SGNA BS freezer defrosted.
Condenser fan should be about 1300 rpm, I believe!
Jun 13, 2012 | GE Refrigerators
I have a GE side by side Fridg.that is approx 7-8yrs old.The freezer side is working fine but the fridg. side is not cooling. staying at about 50 degrees just barely cool.. This seemed to happened...
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Feb 22, 2008 | GE GSS25LGM Side by Side Refrigerator
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
